<<please Help>> - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2006, 09:30 PM   #1 (permalink)
LYR
'74 Corona LYR-382
View LYR's Photo Gallery
<<please Help>>
i jus busted a bolt off in my head!!!! i was replecing the thermostat in my 18R...got it all off ok, but put the second bolt in...did not even get it tight, an i felt that shudder go down my spine as it went soft....
does anyone have any sparkin ideas?? treid an allen key in it, but it snapped too...drilled it out again, an now don know what to do! i got no access to a proper easy-out tool or nothin!!!
Thanks....
LYR is offline   Reply With Quote
Old 03-16-2006, 03:01 PM   #2 (permalink)
View tashirosgt's Photo Gallery
This is a tough one. Perhaps you can grind and file down the end of a bolt or screwdriver and use it as a primitive easy out. Come to think of it, it might work better than an easy out. Those things are so brittle that I usually snap them off. Of course, I usually drill too small a hole and start with too small a size.
tashirosgt is offline   Reply With Quote
Old 03-16-2006, 03:09 PM   #3 (permalink)
View 94_Rolla_Guy's Photo Gallery
id recomend an really good quality easy out, snap-on, bluepoint, use the biggest size possible, maybe try to use some heat too. Failing everything else drill it out and re-tap it
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 03-16-2006, 03:24 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
I dont recommend those easy out tools, never used them, if I break a bolt, I drill it out and clean the threads. If you snap that easy out in there, its gonna be hard as shit to get that out, as you cant drill it with a normal drill bit, because its tempered.
