Originally Posted by brhino692
I am thinking about trying to attempt changing my brake pads on my 03 Corolla. I have never did this before, and I am not very mechanically inclined, but I have seen it done on my car and it did not look too hard. I was wondering if anyone knew of any websites that offer a picture tutorial to changing your pads, and also if anyone had any suggestions as to the type of brake pads I should buy. Also, is there any type of special tools that I may need to do this, other than basic tools that are in everyones garage? Thanks!
Piece of cake...I did both sides in a half and hour
...Two bolts and push the cylinder in with a C clamp(no special tools needed)
...I went to a good ceramic($35 comes with shims attached)
, no more brake screeching on damp mornings and hardly any break dust on my wheels
...Running them 2 years now and still have close to 3/4 pad left ...I will try to find you a site with pictures but I really think you can do it on your own...just be careful with the jacks and car support...Really its very easy to do and auto places want $100+ to do it......good luck...Radd Guy
PS check your rotors for wear and loosen your break fluid reservoir cap before and check fluid /tighten cap after installation you might want to remove a little fluid from the reservoir or just put a rag under the reservoir to catch fluid if it leaks over when pushing the cylinder in!
