88 gorolla gts died - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2006, 09:34 PM   #1 (permalink)
View doomass's Photo Gallery
88 gorolla gts died
I was leaving work and drove my car across the railroad track and it died out a little.I then made a right turn and it went completely dead.I pulled into a parking lot and looked under the hood and seen where the metal bracket that goes across the battery had it the pos+ side of the battery.I checked all the fuses,the ones on the battery cable,fender wall and kick panel.It will turn over and crank and will act like it will want to start for a millisecond and then die.The radio will not work ,heater fan runs real slow and power windows will work just real real slow.My radar detector will not work and its plugged into my lighter.I checked all fuses like i said.I put a brand new battery,new plugs.The starter spins over good,like I said till its fires for a second and dies. i did a code test and its giving me 12,13,51.Any help will be really apprciated.Thanks
BTW its getting gas cause i can smell it.That why i changed the plugs just in case it fouled them fro turning over so much.
doomass is offline   Reply With Quote
Old 03-18-2006, 08:51 AM   #2 (permalink)
Old 03-18-2006, 09:49 AM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
you might wanna calm down and re-write your post.. I couldn't understand anything.
The metal bracket that goes accross had the + side of the battery touching it? You might have killed the battery if that's the case.
Old 03-18-2006, 04:58 PM   #4 (permalink)
Maybe this will help you out dude
http://secure.hop.com/
Old 03-18-2006, 05:41 PM   #5 (permalink)
KDM is in
REN69's Avatar
haha.. nice attitude. good luck getting help now.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 03-18-2006, 06:08 PM   #6 (permalink)
Dont matter .Dudes in the Honda forum figured it out in a about 10 minutes.
Old 03-18-2006, 10:08 PM   #7 (permalink)
KDM is in
REN69's Avatar
Lol that's cause Hondas have more problems than Toyotas. I should know.. I drove 3 and still own one.
Old 03-19-2006, 12:00 AM   #8 (permalink)
View 94_Rolla_Guy's Photo Gallery
if you shorted the battery you may have burned up the ground cables to the engine and chassis. If you wanna test this take a pair of jumper cables hook both clamps on one end to the negative battery terminal, now hook one on the far end to the engine and one to the chassis now try things and see how they work!
now if this works get some 4ga and reground the engine and the chassis to the battery
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 03-19-2006, 09:33 AM   #9 (permalink)
Mr. Nice Guy
canadianae92's Avatar
View canadianae92's Photo Gallery
Yea it's difficult to learn about problems when all we have a little electrical problems exhaust leaks and other minor problems. Hondas on the other hand I always see broke down, hondas are like the ford's of the import world.
canadianae92 is offline   Reply With Quote
Old 03-19-2006, 12:25 PM   #10 (permalink)
In all fairness the honda guys didnt figure it out I was just bustings Ren69 balls for being a smart ass.I wouldnt own a fukkin honda.I tried what you said 94_Rolla_Guy but still nothing.It will fire for 1 second and then just die out.No wipers ,heater .electric windows or anything else works on the inside.Like I said the heater fan will barely run.Thank you very much 94_Rolla_Guy for the help.
Old 03-19-2006, 01:28 PM   #11 (permalink)
Back From the Dead
CorollaINC's Avatar
View CorollaINC's Photo Gallery
Have you checked your fuse box? maybe the main fuse blew..or there is something grounding the whole car.
I . N . C
ALI
CorollaINC is offline   Reply With Quote
Old 03-19-2006, 04:12 PM   #12 (permalink)
i checked all fuses,3 from trhe battery,firewall and the ones on the inside.think a hotwire is grounded somewhere just finding it is the prob.
Old 03-19-2006, 05:13 PM   #13 (permalink)
Back From the Dead
CorollaINC's Avatar
well you gotta start lookin...just follow all your wires...and if this is a car you wanna keep..replace any fucked up wires while your at it
I . N . C
ALI
Old 03-24-2006, 06:04 AM   #14 (permalink)
Thanks rolla_guy thats what i did.I reground and it fired right up.You da Man!!
just got a 88 GTS 89CelicaGTTurbo Celica Forum 3 06-24-2005 02:03 AM
88 GTS engine and 88 GT engine? 90celica Celica Forum 9 06-05-2005 02:53 PM
'88 corolla gts front struts replacement mrcbr929 Archived Corolla threads 3 10-17-2004 03:16 PM
88 Corolla Gts Recalls... Piran21 Archived Corolla threads 10 11-15-2003 01:10 AM
88 Celica GT or GTS celicastyle88 Celica Forum 15 11-01-2002 12:09 PM
