'95 Corolla - Losing Oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2006, 07:12 PM   #1 (permalink)
View laurapf95's Photo Gallery
I love my little corolla, but am losing oil quickly. In the last two years I have put about 40,000 on it and now have around 157,000. I am now losing about a quart of oil every 200 miles. There is no oil after sitting nor is there oil on the engine when you look under it. I haven't seen any smoke from the exhaust. Where is it going? And how do I fix it?
laurapf95 is offline   Reply With Quote
Old 03-17-2006, 07:59 PM   #2 (permalink)
'96 Rolla DX
View SR5_4WD's Photo Gallery
Sounds like something that used to happen to my car not that long ago.
Only my car doesn't do it anymore
SR5_4WD is offline   Reply With Quote
Old 03-17-2006, 09:05 PM   #3 (permalink)
View sledge's Photo Gallery
what to check
check under your valve cover, im pretty sure the 95 has sparkplug tube gaskets inside the valve cover they keep oil from seeping in to the spark plugs. thier should be one for each plug. they can be removed and replaced very easy. i have a 89 corolla 1.6 motor 275000 miles that was doing the same thing no sign of oil leaking it would only smoke on startup changed the timing belt and noticed the cracked gaskets letting oil get on plugs and burn off check it out it will probally take care of your problem for under 20 dollars take care sledge
sledge is offline   Reply With Quote
Old 03-17-2006, 11:54 PM   #4 (permalink)
View 94_Rolla_Guy's Photo Gallery
if its a 1.8L ( 7A-FE ) i would bet ya its the oil control rings! they are known to cause problems!
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 03-19-2006, 12:53 AM   #5 (permalink)
View ghazanhaider's Photo Gallery
Same issue with my 94 Auto Corolla 1.6L Special edition.
Dont quite know where the "oil control rings" go, I'll check Napa for the part. Any other places that sell oil control rings in Toronto?
It burns more than a quart a week. It otherwise runs fine.
ghazanhaider is offline   Reply With Quote
Old 03-19-2006, 09:52 AM   #6 (permalink)
in order to replace the rings your pulling the entire engine apart down to the pistons as the rings seal the piston to the cylinder
Old 03-19-2006, 02:19 PM   #7 (permalink)
Expense?
How expensive are we talking? Not including labor, thankfully my dad will be taking care of that.
Old 03-19-2006, 04:29 PM   #8 (permalink)
View KaMLuNg's Photo Gallery
i would do what sledge said first... check your valve cover gasket and see if that solves your problem first... that is a relatively cheap and easy fix... if that does not solve your problem then check into the internals of your engine... it is better to go cheap first then get into the more expensive steps...
if u pull the entire engine to find out it is not your o-rings, u will be kicking urself if it was only a 35$ valve cover gasket that needed to be replaced... my .02
'01 GS430
'07 Acura TL
'98 3.2 TL
'07 Rolla LE
KaMLuNg is offline   Reply With Quote
Corolla tranny and oil questions dandxg Archived Corolla threads 5 09-16-2005 05:45 PM
Low Gas Mileage 95 Corolla guavachiffon Introduce Yourself Here 1 08-17-2005 01:19 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 05:01 PM
95 Corolla - C52 swap Ukrainian102 Archived Corolla threads 5 10-01-2004 10:04 AM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? gadawg Archived Corolla threads 6 01-26-2004 05:39 AM
