Which one is the EFI relay? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-22-2006, 11:40 AM   #1 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
AE86 Which one is the EFI relay?
I need to check whether or not my EFI relay in the fusebox under the hood is working, but the markings on the cover have since washed off. The owner's manual doesn't have anything useful in it (just fuses), so I need your help. Does anyone have a pic of the markings on the fusebox lid or something like that?
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 03-22-2006, 11:42 AM   #2 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
What year?
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 03-22-2006, 04:58 PM   #3 (permalink)
4Aaron GE's Avatar
87
Old 03-22-2006, 09:34 PM   #4 (permalink)
View micro214_kp61's Photo Gallery
Aaron.. should be the same as 1986 right? if yes i'll take a photo of my bro's car.
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 03-22-2006, 09:40 PM   #5 (permalink)
View dannyb43's Photo Gallery
The only year that had a different wiring harness under the hood was the 85 and early model 86. The fuse panels were the same if i remeber corectly, but the harness under the hood didnt have the conector port for the compuiter diagnostics.
Dan
dannyb43 is offline   Reply With Quote
Old 03-22-2006, 10:42 PM   #6 (permalink)
4Aaron GE's Avatar
Thanks, Mike.
Old 03-23-2006, 03:57 PM   #7 (permalink)
View Twincam16's Photo Gallery
Here's one from an '85.
http://memimage.cardomain.net/member...32_50_full.jpg
Twincam16 is offline   Reply With Quote
Old 03-23-2006, 05:42 PM   #8 (permalink)
4Aaron GE's Avatar
Thanks. Let's see how well that matches up.
Old 03-24-2006, 02:42 AM   #9 (permalink)
Gameroom cash: $134355
and actually a lot of the relays are the same.... i've played switcheroo between several mr2's and trying different relays...... usually no difference
Old 03-24-2006, 12:29 PM   #10 (permalink)
4Aaron GE's Avatar
Excellent. Time for a junkyard run then!
EFI fuse, fuel pump, and a shit load of wires... brownyy2 Camry & Solara Lounge 2 12-11-2005 08:25 PM
Need Help With a Relay Problem Dr Tweak Hardcore Tech and Competition 1 02-15-2005 03:43 AM
Temp gauge relay [gen2] Zfreeman 1st & 2nd Generation (1983–1986 & 1987-1991) 9 08-21-2004 07:00 PM
EFI relay over heat? deltree Camry & Solara Lounge 2 04-15-2004 03:40 PM
