'91 CEL (check engine light) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2006, 02:15 AM   #1 (permalink)
Cressida nut
Gameroom cash: $251045
View kamesama980's Photo Gallery
I'm working on a friends '91 corolla AE92 5 speed in the morning. problems are: constant illuminated CEL and funky tacho.
CEL: no noticable problems such as lack of power, poor running, bad mileage, etc. just a constant CEL. anyone have an online manual, preferrably the TSRM or at least a CEL report list and is the procedure similar to other toyotas: short terminals (which ones?) in the engine bay connector and count flashes?
tach: doesnt do anything when first started, slowly rises over a few minutes as the engine warms up (maybe...5-8 minutes driving) up to about 1500. after that it seems to work OK. tacho is prolly the least important gauge, merely a quantification of what you can hear..but its nice to have it working since its there...looks better.
I do a lot of work on my 88 cressida, so im not engine-illiterate. i also spend way too much time on the cressida forum, so im not forum illiterate, i tried searching and didnt get anything.
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'90 Suzuki VX800
"You don't get to judge me for how I fix what you break"
kamesama980 is offline   Reply With Quote
Old 03-24-2006, 03:18 AM   #2 (permalink)
View AVANT's Photo Gallery
Sounds like he might need a new dizzy.
My FX16 ran fine, but I kept getting this stupid check engine light warning me about the "rpm signal". Found an awesome condition dizzy @ a wrecking yard, plugged it in, CEL went away immediately. Although my car is a 4AGE, I'm guessing the 4AFE still atleast have a similar setup.
1987 Corolla FX16 GTS. 4AGE powered.
AVANT is offline   Reply With Quote
Old 03-24-2006, 06:07 AM   #3 (permalink)
View OEMonkey's Photo Gallery
Pull the code first. Jumper TE1 and E1 w/ the KOEO. Then clear it by pulling the 15A EFI fuse and see if the CEL comes back w/ the same code.
OEMonkey is offline   Reply With Quote
Old 03-30-2006, 02:14 AM   #4 (permalink)
Cressida nut
how much did the dizzy cost if you dont mind? will changing the cap and/or roter fix it maybe? given that the dizzy itself is mechanical, the electrical parts are the cap and roter.... cheaper=better. still havent gotten the chance to check the CEL.
'90 Suzuki VX800
Old 04-16-2006, 03:46 PM   #5 (permalink)
Cressida nut
opened the dizzy cap and there was a few grains of sand in there, and some corrosion on the terminals. nothing a little wire brush work didnt solve. pulled the codes this weekend, getting 25 and 26...for my 88 cressida, that means rich and lean respectively, im guessing its the same for the corolla. it could probably use a new O2 sensor but what else should i look into for having both rich and lean conditions? MAF sensor (?), vacuum leaks, injectors on the way out? the car seems to run OK. certainly considering its got 160K+ miles.
'90 Suzuki VX800
Old 04-20-2006, 11:21 PM   #6 (permalink)
Cressida nut
Don't tell me I've stumped the great and massive toyotanation forum? great...
'90 Suzuki VX800
check engine light Islandtrix 1st Generation (2003-2008) 17 03-05-2009 01:02 AM
Traction Light with P0135 check engine code fincobbler Solara 8 05-01-2008 07:51 AM
1995 corolla check engine light ltnflvr Archived Corolla threads 6 01-12-2007 11:23 AM
Traction Light with P0135 check engine code fincobbler Solara 1 02-17-2006 08:50 PM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
