Belt sqeaking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-26-2006, 09:28 PM   #1 (permalink)
View VaRolla91's Photo Gallery
AE92 Belt sqeaking
Hey people,first off thanks In advance...I just replaced my Alternator in my 1991 Corolla DX...went ahead & got a new belt too...and it sqeaks now when i start the car up...Whats up? do i have to much tension on it? Not enough? or does the belt just need to get...i dunno..Broke in??? cuz man..its annoying makes my car seem like Junk when i start it up...Cant stand broke stuff on the ride...Any help is appreciated
VaRolla91 is offline   Reply With Quote
Old 03-26-2006, 10:24 PM   #2 (permalink)
View epyon22's Photo Gallery
well how good are you with cars? if your fairly decent you can check the belts your self just look to one side of the engine on my car its the side farthest away from the battery and if you look down youll see some belts push on them. they should move a little under pressure not too much though. if they are loose or too tight fix acordingly. and if not mabe somthing that the belt runs is sticking a little like the new alternator or somthing else
'89 ae92 GT-S bought brand new dec '88
http://photobucket.com/albums/v227/epyon22/car/
epyon22 is offline   Reply With Quote
Old 03-26-2006, 10:53 PM   #3 (permalink)
View littlewings's Photo Gallery
check ur pulley. might the bearing inside the pulley that have problem.
zzzz....
littlewings is offline   Reply With Quote
Old 03-26-2006, 11:00 PM   #4 (permalink)
View AVANT's Photo Gallery
If it's squeeking on a new belt, then there isn't enough tension, nuff said. Tighten it up more. I always have to hammer the alternator a little bit inorder to get enough tension. Just pushing the alternator down all the way by hand is never enough.
1987 Corolla FX16 GTS. 4AGE powered.
AVANT is offline   Reply With Quote
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 09:06 AM
Timing belt tension spring's purpose AFTER belt install? awmccready Camry & Solara Lounge 4 09-20-2009 02:59 AM
Help me with correct belt size- underdrive crank pulley for 5SFE cman2000 3rd & 4th Generation (1992–1996 & 1997–2001) 13 01-24-2005 09:05 PM
non-interference engines?? 90celica General Discussion 13 11-09-2004 10:34 PM
