Friction noise from rear wheel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2006, 01:01 PM   #1 (permalink)
'96 Rolla DX
View SR5_4WD's Photo Gallery
Canada Friction noise from rear wheel
My passenger side wheel makes some type of friction noise when going down the road.
What could this be? It's not a major friction, but something needs grease by the sounds of it.
SR5_4WD is offline   Reply With Quote
Old 03-27-2006, 02:05 PM   #2 (permalink)
View karazy's Photo Gallery
First check the splash guard on the inside of the wheel. If ok, check the brakes to see if they are alright. Before you take the tire off to check the brakes, check the bearing.
karazy is offline   Reply With Quote
Old 03-27-2006, 02:17 PM   #3 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
Mine does the same thing at about 35-50 mph drives me nuts but I think mine sounds like the tire threads(only 3K on the tires)..I'm going to have my tires looked at by the place I bought them from if their OK then its the next step in the brakes and bearings check...I have the split seats in back and had one down carrying some wood the other day and it was really bad was coming from the drivers side..I'll keep you posted...good luck...Radd..
Raddman is offline   Reply With Quote
Old 03-27-2006, 06:01 PM   #4 (permalink)
'96 Rolla DX
really, oh so it could even be the tires??? My winter tires are honestly 10 years old no joking. They have a canadian tire logo on the sidewall!! Perhaps I will put my summer ones on before I start screwing with brakes etc. Thanks everyone
PS how do you check the bearing, and what should I look for?
Old 03-27-2006, 06:46 PM   #5 (permalink)
Registered User
Raddman's Avatar
USA
I don't know ether but when I get it checked I will let you know ...Maybe could get a repair book that had a blow up of the rear...My sound is almost like road noise a intermittent humming sound not scraping like a brake or something rubbing ...I had uneven wear in my front tire last year that made that same pattern sound that's why I think its my tires...lol..might be ones thats under inflated I'll have to check it out ...Radd
Old 03-27-2006, 07:31 PM   #6 (permalink)
View 03mooncorolla's Photo Gallery
Canada
As for checking the rear bearings
Jack up the vehicle, place an axle stand under for safety and grab the top and bottom of the tire, push in on one end and pull out on the other checking the amount of play found.
A little may be ok depending the spec's allowed for you year and model, if you do find movement compare it with the other side for an equal amount.
Also spin the wheel while you have it up and listen if it sounds rough or different from all others then that's the wheel you are having problems with.
As for checking the condition of the bearing you could pull off the bearing cap and check the grease if it looks all dried up it's time to get it cleaned and checked.(for Rear drum breaks)
Am I correct in thinking you have a 4 wheel drive, if so then the cap won't be there as you may have rear disks? I would say if your going into this further you'll need to get a manual.
My answer is a general one, and I'm not sure of the specifics of your vehicle. But start with the small stuff first
Hope this helps at least
03mooncorolla is offline   Reply With Quote
Old 03-28-2006, 06:32 AM   #7 (permalink)
'96 Rolla DX
Thanks. its 4wd but I do have drums in the rear.
Wheel noise and Fender wall Hole Super Kaioken Camry & Solara Lounge 11 06-07-2006 06:00 PM
Rear rattling noise fixed Phi Camry & Solara Lounge 2 09-15-2005 08:08 AM
Noise associate with steering wheel? T2000 Camry & Solara Lounge 1 08-11-2005 12:18 PM
Wierd noise when i turn the wheel PoR2GeEzCamry Camry & Solara Lounge 7 05-16-2005 07:21 AM
