4agze camshafts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-29-2006, 02:33 PM   #1 (permalink)
View GraphiteRolla's Photo Gallery
4agze camshafts
I have swapped the levin 4agze into my 94 corolla and now I am looking at some camshafts. I see a lot of people going with two different sizes and I was wondering why that is? I am not looking for a monster because I used the stock (c52 I think) tranny and don't want to break it. The ones I am looking at are ..Intake 272Degrees 8.35MM Lift. Exhaust 264Degrees 8.1MM Lift. Anyone with a 4agze already have camshafts and know what produces a good amount of power without being unstreetable? New hks cam gears and valve springs will be going in with whatever size i go with and I am going to eventually do an hks pulley kit and intercooler sprayer.
GraphiteRolla is offline   Reply With Quote
Old 03-29-2006, 04:10 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Usually the "mildest" cam will give you a decent gain without having to upgrade ECU or anything like that. I believe there's a milder cam than the one you're looking at.
Old 03-29-2006, 07:28 PM   #3 (permalink)
View epyon22's Photo Gallery
the ones you are looking at are right on the verge of going past the stock ecu's ablity to run with here's a 4age tuning site should help you a bit more with cam selection http://www.billzilla.org/4agmods.htm
'89 ae92 GT-S bought brand new dec '88
http://photobucket.com/albums/v227/epyon22/car/
epyon22 is offline   Reply With Quote
Old 03-29-2006, 07:45 PM   #4 (permalink)
View AVANT's Photo Gallery
If you want more power and stay streetable, it'll be better choice to go with more boost instead. That way, your idle and non-boosted conditions will remain the same making it more drivable, easier to pass smog, and keep your gas milage (for normal driving).
1987 Corolla FX16 GTS. 4AGE powered.
AVANT is offline   Reply With Quote
Old 03-30-2006, 05:42 AM   #5 (permalink)
The TN Member
View punter's Photo Gallery
Exactally, generally you should worry about the cams on a FI motor (especially a 4agze) instead look at the exhaust and more boost.
punter is offline   Reply With Quote
Old 03-30-2006, 09:08 AM   #6 (permalink)
View micro214_kp61's Photo Gallery
use the camshafts from the T-VIS bigport.
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 03-30-2006, 12:28 PM   #7 (permalink)
Gameroom cash: $134355
^^^ early tvis bigport... 85/86 are slightly bigger than 87-89..... this is what most gze guys do
4AGZE Transplant 2CAMS Archived Corolla threads 5 12-12-2005 05:17 PM
4agze into a 95' Prizm RadRacer3 Archived Corolla threads 58 11-17-2005 05:32 PM
about 4agze swap Vanna Celica Forum 0 07-29-2004 12:06 AM
4agze w/auto swap ? SuperV Archived Corolla threads 0 02-13-2004 01:29 PM
