Remove backseat off 97 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2006, 07:42 AM   #1 (permalink)
cinnabar's Avatar
View cinnabar's Photo Gallery
Does anyone have any clue on how to remove the rear seatback? Mine's a base model so it doesn't have the little lever up top on the corners where you can pull them forward. I'm trying to access the strut towers and from the looks of it I can't really do much in the trunk. I have the repair manual from toyota but it's not really helpful.
Get R Done
cinnabar is offline   Reply With Quote
Old 03-30-2006, 10:16 AM   #2 (permalink)
View Blackstone's Photo Gallery
The bottom section that you sit on should snap in/out. A good tug upward on the front edge will get it out, then you'll see 3-4 12mm bolts which hold the back portion of the seat. Remove those and push the cushion upward to pop the upper hooks from their pockets. This is the setup for '94, yours should be similar.
Blackstone is offline   Reply With Quote
97 corolla check engine light on GKK Archived Corolla threads 5 09-22-2005 01:32 AM
How to Remove 2004 Corolla S Side Skirts, Front and Rear Spoilers??? jluksic Archived Corolla threads 4 01-21-2005 08:15 AM
97 corolla rear speaker removal/installation MickeyMouse Audio, Video, and Security - Tech 3 12-30-2004 10:28 AM
97 Corolla Defogger relay? Kens 97 Corolla Archived Corolla threads 5 12-13-2004 05:00 PM
