'98 VE starting problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2006, 11:59 AM   #1 (permalink)
View ADRYMVRNC's Photo Gallery
I have a '98 corolla VE with 120K mi and I have been having a problem with starting the car. It clicks when I try to start it and it will do this about 10x's then try to start and if i give it gas it will keep the start. If it's been running for awhile it will start again, but after it sits for a long time it does the same thing again. I had the battery replaced and I still have the same problem. Does anyone have any ideas what this might be? Thanks. Audrey Illinois
ADRYMVRNC is offline   Reply With Quote
Old 03-31-2006, 02:42 PM   #2 (permalink)
Bingo's Avatar
View Bingo's Photo Gallery
A failing starter ? Bingo
Bingo is offline   Reply With Quote
Old 04-01-2006, 05:31 AM   #3 (permalink)
'98 VE starting problems
I think you're right. I'll have to have it checked out. Thanks Audrey Illinois
Old 04-02-2006, 12:31 AM   #4 (permalink)
View rlee777's Photo Gallery
Common issue with Corollas. You probably have worn starter contacts. Should be under $12 at the dealer for the parts.
Pull out the starter. Remove the three bolts holding it together. Look at the copper contacts inside and replace in the same orientation. You will probably see deep grooves in the old contacts. Reassemble and install back into the car.
Good DIY project that will save you $$$ (new starters begin at $150 before labor)
rlee777 is offline   Reply With Quote
Old 04-02-2006, 07:28 AM   #5 (permalink)
'98 VE starter
I can't thank you enough for the info! My dad had said it might be that too. It seemed to do this before only when it was damp or rainning out???? Strange! It would sure be cheaper to replace those so I hope that's what it is too! Thanks again.
1985 Pickup starting problem...HELP twinturbonoy Pre-88 Toyota Pickup/Hilux 10 03-15-2006 01:25 AM
Help - Problem with 1994 Celica Starting bpate Celica Forum 2 11-02-2005 08:10 PM
HELP, problem starting car. dthepit Camry & Solara Lounge 5 08-12-2005 05:19 PM
Starting Problem scottmunster Archived Corolla threads 4 07-29-2005 11:15 AM
