how important is the torque? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2006, 11:38 AM   #1 (permalink)
cinnabar's Avatar
View cinnabar's Photo Gallery
I just need to know how critical the factory torque specs are for the strut assembly. My repair manual from toyota says it should be around 203ft/lb for the 19mm bolts that connect my new tokico struts to the control arm. I don't have any torque wrenches that I can measure the torque but my hammer wrench seems to get it pretty tight at 120psi. is this ok or should I follow specs?
I'll probly ask my alignment guys to check them once I'm done putting the struts on anyway.
Get R Done
cinnabar is offline   Reply With Quote
Old 04-01-2006, 02:42 PM   #2 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
well they don't want the bolt to losen while you drive or for things to move as you hit bumbs and shit, so I would say pretty important
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 04-01-2006, 03:40 PM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
I shot mine on and off with a bolt gun
Old 04-01-2006, 05:38 PM   #4 (permalink)
Vroom?
freakinbox's Avatar
impact gun? hell those can break bolts, Most likely your are tight enough or to tight. to tight can be just as bad, damaging parts and such.
Old 04-01-2006, 09:16 PM   #5 (permalink)
Mr. Nice Guy
canadianae92's Avatar
View canadianae92's Photo Gallery
actually a problem with the impact gun is that it can actually be to lose, happened to me while i was doing a pizza delivery i heard thump thump thump so i pulled over and lugs where lose all around on the front(this was after changing my clutch) and yes the lugs where put on tight as possible with the impact gun.
canadianae92 is offline   Reply With Quote
Old 04-01-2006, 09:38 PM   #6 (permalink)
cinnabar's Avatar
That's that I suspected. I found I could tighten them even more with just a wrench and some pure brute force. I'll have them checked anyway when I go for an alignment.
Get R Done
Old 04-02-2006, 12:08 AM   #7 (permalink)
View rlee777's Photo Gallery
ALWAYS use a torque wrench when working with suspension parts. It is critical for the parts to operate with the right torque specs, especially the strut to steering knuckle (203 ft/lbs) bolts. These hold the camber and under torqued bolts is a safety hazard. Buy or borrow at Autozone a torque wrench. Do it right, especially with the suspension!
rlee777 is offline   Reply With Quote
Old 04-02-2006, 01:00 AM   #8 (permalink)
Vroom?
freakinbox's Avatar
depends on the impact gun, some aren't strong enough for lug nuts. we have several at the shop, different sizes and such
Old 04-02-2006, 12:42 PM   #9 (permalink)
View Maxpayne124's Photo Gallery
my ingersoll impact goes to 1000ftlbs so i dont have to worry about not having enough torque BUT heres a motto to go by: "tight is tight and too tight is broken"
780tuners.com
corollacustomz.ca
toyotanation.com
Maxpayne124 is offline   Reply With Quote
Old 04-02-2006, 05:05 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
Obviously you missed the number 1 rule about putting on tires, you always check the lugnuts after a while to see if they loosen, rims tend to live a bit, and the lugnuts can loosen while driving.
Mystery Rolla wiccanferret Archived Corolla threads 20 04-07-2005 01:22 AM
what is a torque mount? Protocold Camry & Solara Lounge 1 03-18-2004 01:35 PM
diff between torque and HP mrbacardi Hardcore Tech and Competition 10 09-23-2003 02:28 PM
How to apply 200 ft lb torque w/ 150 ft lb max torq wrench? Corbett Archived Corolla threads 11 09-26-2002 04:07 PM
no more frowning on A/T cars! Go! project trueno General Discussion 12 12-14-2001 09:54 AM
