Help!!! Clutch pedal doesn't do anything!!
Ok, I was on the highway in 5th gear, and I started to go up a hill. Since I was taching low to begin with; I had to downshift. Instead of going to 4th, I wanted to race up the hill and shift into 3rd, as I have done many times before (at the speed I was going it would be about 4500 in 3rd).
Anyways, I missed 3rd (as it is late, I was coming home from a concert, and I've been up since early this morning with 3 hours sleep the night before), and now I have a real big problem.
My clutch pedal has little to no resistance. If I am in neutral and I start the car, I can't shift into any forward gear, and reverse grinds like a bitch; so I know the clutch isn't disengaging.
When I put the shifter into 1st and start the car (and pump the gas so it starts in gear), I can rev match to shift up through the gears. Once in 3rd or higher, the clutch works; though only at the last inch or so of the pedal. It DOES disengage.
The fluid is full, and when you pump the clutch I can see the fork moving (or at least the boot on the front of my tranny)
What did I do to my poor car?
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
