Blue top to Red top - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2006, 10:05 AM   #1 (permalink)
young drifter
View -HiTMaN-'s Photo Gallery
AE86 Blue top to Red top
Hey guys, just have a few questions regarding my motor swap. i had to abandon my 20V swap due to time and part availability. So instead i purchased a 16V red top for my 86. so now i have the two motors side by side in the garage. i just have a few quick questions before i tear into the motors.
Are there any specifics that i need to adress when doing the swap. i know i need the T-VIS eliminator plate (allready purchased). i got a new clutch, but that's about it. i noticed some differences as far as cooling, and a few harness plugs. I have my original blue top ECU, whicih should be sufficient to run this motor cosidering the fact that i'm changing the manifold.
So that's about it, just looking to see if there are any known issues that need to be adressed. Any replies are greatly appreciated. Really want to finish this so i can start coming to the meets again.
Thanks guys.
Cars:
87 AW11
91 Honda Accord EX-R 5 speed
Cell: GTA Area:
(647) 884-8324
-HiTMaN- is offline   Reply With Quote
Old 04-02-2006, 01:16 PM   #2 (permalink)
Gameroom cash: $134355
which "redtop" is it? is it a bigport redtop (ie, a tvis motor) or a smallport redtop (non tvis, with an oildrain back on the back of the head by #4)
if it's the first, then you basically bought the same motor you already have (only a heavier crank and stronger block), if it's the second then you're ready for business
i'll help ya more when you say which it is
Old 04-02-2006, 03:38 PM   #3 (permalink)
View AVANT's Photo Gallery
http://forums.club4ag.com/topic.asp?TOPIC_ID=120356
http://forums.club4ag.com/topic.asp?...TOPIC_ID=66430
Good read to give you lots of info.
1987 Corolla FX16 GTS. 4AGE powered.
AVANT is offline   Reply With Quote
Old 04-02-2006, 05:35 PM   #4 (permalink)
The TN Member
View punter's Photo Gallery
Why are you removing TVIS?? and yes your bluetop ECU will run a redtop just fine.
punter is offline   Reply With Quote
Old 04-02-2006, 08:57 PM   #5 (permalink)
4A-GZE
KnightX_AE86's Avatar
View KnightX_AE86's Photo Gallery
i dun think the redtop ever came with TVIS =S
KnightX_AE86 is offline   Reply With Quote
Old 04-02-2006, 09:31 PM   #6 (permalink)
View lex_addict's Photo Gallery
smallport redtop = no TVIS
1992 ls400
1987 corolla gt-s [coupe]
lex_addict is offline   Reply With Quote
Old 04-02-2006, 10:00 PM   #7 (permalink)
The TN Member
There was a redtop tvis. Still not sure which one he has, but after rereading his post I'd say its most likley he has a smallport. In which case I wouldn't be so sure about running a bluetop ecu.
Old 04-02-2006, 10:05 PM   #8 (permalink)
View epyon22's Photo Gallery
bigport redtop = tvis
'89 ae92 GT-S bought brand new dec '88
http://photobucket.com/albums/v227/epyon22/car/
epyon22 is offline   Reply With Quote
Old 04-03-2006, 11:19 AM   #9 (permalink)
young drifter
its a small port, NON T-VIS. That's why i had to get the Tvis eliminator plate, to take up the space where tvis used to be, because i'm using the blue top intake manifold
Cars:
87 AW11
Cell: GTA Area:
(647) 884-8324
Old 04-03-2006, 04:09 PM   #10 (permalink)
The TN Member
Just had a talk with a mate of mine who has gone through about 6 4age in his race car, and was told that as long as you use everything from the bluetop it will run fine, that's all blue top electrical parts.
So that sounds promising, Good luck with it.
Old 04-04-2006, 03:26 AM   #11 (permalink)
you'll have a flat spot in the middle of your rpm's.... the 210cc's are a bit small
Old 04-07-2006, 10:26 PM   #12 (permalink)
young drifter
AE86 flat spot eh?
ok, well this might be a stupid proposition, but here goes anyway. what if i use the injectors from the red top and the same fuel rail. i was thinking of splicing the wires on the injectors and using the blue top connectors on the red top injectors. not sure if it will work, but if they both have 2 wire leads shouldldn't it work....theoreticaly? i dunno. its eithr that or using supra injectors i heard will work.
if anyone knows let me know. cuz that's prety much the only thingh olding me back. this and the cooling system. the blue top is a lots impler then the red top.
Cars:
87 AW11
Cell: GTA Area:
(647) 884-8324
Old 04-08-2006, 02:30 AM   #13 (permalink)
impedences are different between the smallport injectors & bigports.......
Old 04-08-2006, 03:13 AM   #14 (permalink)
The TN Member
and they have different flow rates. The redtop ones are bigger, which if used with a bluetop ECU will make it run really rich.
Say no to huge pics as signatures.
Old 04-08-2006, 09:08 AM   #15 (permalink)
young drifter
Thanks a lot guys, i really appreciate the help.
Gonna try and reuse my blue top fuel rail and injectors. again, only thing left prety much is the coolilng system to figure out. thanks again everyone
Cars:
87 AW11
Cell: GTA Area:
(647) 884-8324
1989 Corolla GTS Red Interior? calvinapr Archived Corolla threads 3 08-13-2005 03:55 AM
Top Speed/Gearing for Corolla. Chris Corolla S Hardcore Tech and Competition 23 10-29-2002 10:07 PM
what's all this hype with the 20V Lafora Archived Corolla threads 36 04-09-2002 09:22 AM
