Sludge in the coolant reservoir tank - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2006, 07:42 AM   #1 (permalink)
View fredsc's Photo Gallery
Post Sludge in the coolant reservoir tank
Question regarding a 1991 Corolla commuting vehicle, driven 60 miles a day, total mileage 138,000. For the first time I noticed that there is some sludge in the plastic engine coolant reservoir. I last replaced the coolant 12 months ago. Is there a possible engine gasket problem? What should I do?
I also have a slow oil leak which I believe is occurring at the oil plug. I put a new metal gasket, which looks like a washer, on but since doing so can't seem to get the oil plug tight enough to stop the leak. The oil pan is rusty but I don't thing it's leaky. I'm thinking of removing the gasket (washer) and just going with the plug. Your thoughts?
fredsc is offline   Reply With Quote
Old 04-04-2006, 09:16 PM   #2 (permalink)
View 03mooncorolla's Photo Gallery
What colour is the sludge?
03mooncorolla is offline   Reply With Quote
Old 04-04-2006, 09:21 PM   #3 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
if oil got into your coolant, itd look milky
most likely sediment/rust
do a nice flush =)
WhiteRabbit is offline   Reply With Quote
Old 04-04-2006, 10:02 PM   #4 (permalink)
In love with boost
emiliorescigno's Avatar
View emiliorescigno's Photo Gallery
My old 1991 Corolla had the same problem, in my case it was engine oil leaking into the coolant (the sludge would return not long after a flush). I suspected it was the headgasket but in my case I didn't bother fixing it, it would have cost more than the car is worth.
Hopefully a flush will take care of it and it won't come back!
emiliorescigno is offline   Reply With Quote
Old 04-04-2006, 10:32 PM   #5 (permalink)
TN's furry friend
use prestone's super flush, the one you run for 3-6 hours, then use prestone's anti-rust
Old 04-05-2006, 03:16 AM   #6 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
wouldn't cost that much if you did it yourself. But it most cases you can get a 4afe a 4age for the price of head gasket. But still all you have to do it pull the head pull the lifters. Take the lifters in to be machined, Clean all the sludge out, put it back together
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Brand of Coolant stir_fry_boy Camry & Solara Lounge 51 01-12-2006 10:45 AM
Coolant Tank eirik MR2 Forum 2 12-14-2004 08:58 AM
Coolant overflow tank problem Candiman Camry & Solara Lounge 0 03-23-2003 11:49 PM
