Lost 4th Gear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2006, 02:22 PM   #1 (permalink)
View Hidshadows's Photo Gallery
Lost 4th Gear
I drive a manual 99 corolla and on a long road trip I seemed to have lost 4th gear. There is no grinding or other sounds when I attempt to engage 4th gear and the stick cannot be moved completely into the 4th gear position. I am assuming this is a linkage problem but instead of hunting for the problem I'm hoping others would have had this problem and provide an easier solution thanks.
Hidshadows is offline   Reply With Quote
Old 04-03-2006, 04:30 PM   #2 (permalink)
The TN Member
View punter's Photo Gallery
Probably a bent selector fork, You have to pull the gearbox apart to fix.
Does it select all other gears and still drive normally?
punter is offline   Reply With Quote
Old 04-03-2006, 06:40 PM   #3 (permalink)
Ya all the other gears work fine. Looks like a summer project then. Thanks.
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
22re auto missing 4th gear djbeefyaz 89-95 Toyota Pickup/Hilux 19 05-24-2007 10:40 PM
'05 Taco Speed/RPM charts Sonny 2nd Generation (2005+) 4 03-11-2007 01:08 PM
4th gear oscillation??? koloteamr Camry & Solara Lounge 4 01-04-2006 05:12 PM
Engine Misses in 4th and 5 gear Blakbat Pre-88 Toyota Pickup/Hilux 1 10-07-2005 11:00 AM
