ring gear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2006, 08:36 PM   #1 (permalink)
Drive_a_toy's Avatar
View Drive_a_toy's Photo Gallery
AE92 ring gear
hey hey......thanks for asll your help from b4 on fixing my ignition coil....
i think my ring gear has started to loose teeth. i go to start engine. starter grabs for like half a second.then freeweels......then wen it stiops i do it again and again.usually like 4 tries......and engine starts,.....this sux because i do not have the facilities to drop my tranny and replace ring gear....and no $$$ to get a shop to do it!!!!!!
any input or sugestions would be appreciated.....
BTW the search only brought up threads on diffs and gear box questions.......
Red 1990 Toyota Corolla SR5 3xxx,xxx kms Ae92 4A-FE engine....STOCK !!!
Drive_a_toy is offline   Reply With Quote
Old 04-04-2006, 03:36 AM   #2 (permalink)
View 94_Rolla_Guy's Photo Gallery
More than likely its the starter not the ring gear! they make the starters gear softer than the ring gear so it is sacrifical.
A good thing to do is remove the starter inspect its gear then put a 17mm socket on the crank pulley bolt and turn the engine and inspect the ring gear through the starter hole
even if you have to pull the trans its easy, all you need is a couple jackstands and a jack and basic metric tools...
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 04-04-2006, 06:23 PM   #3 (permalink)
good news
hey thats great
this weekend i will take a look.......
thanks alot
is there a ring gear itself or is it part of the flyweel?
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
'05 Taco Speed/RPM charts Sonny 2nd Generation (2005+) 4 03-11-2007 01:08 PM
A story about my school class ring... epinionator89 Off Topic 6 08-20-2005 06:20 AM
Forgot loctite on ring gear bolts, detrimental? Taco30 Hardcore Tech and Competition 4 02-24-2004 05:09 PM
