91 corolla, wont start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2006, 10:24 PM   #1 (permalink)
View mutown's Photo Gallery
91 corolla dx, 2wd, stationwagon. was running fine, engine light came on, pulled over to check. won't start back up. new alternator, battery, coil, cap, rotor, plugs and wires. book says only thing left is ignitor, super expensive. what else could it be?
mutown is offline   Reply With Quote
Old 04-04-2006, 03:24 AM   #2 (permalink)
View 94_Rolla_Guy's Photo Gallery
easiest thing to do is get a second hand distributor if thats where you want to go,
1. are you getting spark?
pull a plug put it in the wire then put the outer body against something metal, have someone crank it, you see a blue spark?
-if yes then its most likely a fuel problem
-if no then turn the motor over with the dist cap off to see if the rotor is spinning
2. getting fuel???
turn the motor over a few times pull a spark plug... are they wet??
-if there wet or smell like gas then you have fuel
-if there dry no fuel!
Check the basics to see whats going on before you spend more money
other wildcard idea would be the timing belt is broken?, try #1 to see if the rotor spins
Also might wanna check what code your getting, from the ECU, someone else will have to help with that proceedure i know you wont need any special tools just dont know the terminals to connect to!
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
91 Corolla DX SW- 20V 4AGE??? OmegaZZ Archived Corolla threads 2 02-19-2005 08:42 PM
'91 corolla radio swap issues peterism03 Archived Corolla threads 4 09-20-2004 05:43 AM
3 Week Old 2005 Corolla Won't Start ErinS3204 Archived Corolla threads 25 08-06-2004 08:42 PM
