New to site and have some questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-05-2006, 11:20 AM   #1 (permalink)
View JDeere5105's Photo Gallery
Question New to site and have some questions
I have a 1999 Toyota Corolla VE that I just recently purchased and have a few questions. The 99's have a timing chain and not a belt? Correct of incorrect? Also have a noise in the front end that is not motor related. I had the tires rotated and balanced. I also had an alignment done. The front left tire was cupped out some. My question is the noise that I am still hearing is that the tire or a bad wheel bearing? Any thoughts or input will be appreciated.
Thanks
Jason
JDeere5105 is offline   Reply With Quote
Old 04-05-2006, 02:52 PM   #2 (permalink)
View JohnO356's Photo Gallery
A tire cupping is usually a sign of a bad strut. A bad strut could also cause noise. What type of noise is it? I've had a bad strut cause tire wear that sounded like a "slap".
JohnO356 is offline   Reply With Quote
Old 04-05-2006, 03:23 PM   #3 (permalink)
Sounds like an out of balance tire but I know that it is not it
1999 Toyota Corolla VE 5 speed
Old 04-05-2006, 06:02 PM   #4 (permalink)
The bounce test to check your struts isn't reliable on the Corolla since the car is so light. Any decent tire/frontend shop can diagnose your strut/front end problems. BTW, timing chain.
Old 04-05-2006, 06:43 PM   #5 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
Thanks
Jason
You never said that when you rotated the tires if the sound went away or to the rear? I had cupping on my front tires and it was from over-sized tires, they threw my caster angle off....And it did make a road noise...I had an alignment done also and that's when they told me of my problem the over-sized tires were throwing my caster angle off....What did the alignment printout say, it should have told you how your alignment was before and after, if you had bad struts they would have told you also...Also if your bearings are bad if you jack the front tire up and spin it you should hear a sound...My guess its that cupped tire any little imperfection on a tire will make a sound...good luck
Raddman is offline   Reply With Quote
