A4FE or A4GE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2006, 09:28 AM   #1 (permalink)
View BigFan3's Photo Gallery
A4FE or A4GE
I'm woking on a 1990 corolla DX
4dr/at/ps/ac/pb.
208,000 miles.
the book says it has an a4GE motor and the local toyota dealership agrees when i give them the vin. (2T1AE94A0LC055846)
From what I've seen so far this is an a4Fe motor. It has dual cams but only one cam works off of the timing belt and the other works off the gears from the first cam.
The a4Ge shows two external cam-gears ... one on each cam with the timing belt going around -both- cam gears.... as oposed to the belt only going around one gear in my case...
Did someone swap out motors at some point?? or am i totally wrong on this?
BigFan3 is offline   Reply With Quote
Old 04-06-2006, 10:53 AM   #2 (permalink)
View tashirosgt's Photo Gallery
If your cams are that way and also have a timing belt instead of a timing chain, then you have a 4A-FE head. So you are correct. Various inconclusive messages have appeared on the forum about putting 4A-FE heads on 4A-GE blocks or vice versa. Going from memory, the 4A-GE engine has an oil cooler that would show up as a tube running from the place where the oil filter attaches to the cooler.
tashirosgt is offline   Reply With Quote
Old 04-06-2006, 04:56 PM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
4 A FE and 4 A GE dude.
Jeez, I just answered a similar thread like 2 weeks ago, I posted pictures and everything to show how different the motors look from each other, etc...
SEARCH BUTTON HELPS!
This is a 4AGE if your motor doesn't have TWIN CAM 16 VALVE on the upper cam cover, then its a 4AFE.
And this is a 4AF.. the 4AFE is fuel injected instead of carbed, but its still the same basic motor.
Old 04-06-2006, 05:20 PM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
you'd have the 4afe stock! all sedans came with the 4af or 4afe.
the gts came with the 4age
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 04-06-2006, 07:04 PM   #5 (permalink)
KDM is in
REN69's Avatar
Thanks.. forgot to point that out.. all AE92 sedans (except the Prizm GSi) and SR5 coupes came with the 4AF (88-89) and 4AFE (90-92)
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 04-06-2006, 07:19 PM   #6 (permalink)
Vroom?
freakinbox's Avatar
hmm according to the mechanic repair manual which is SUPER detailed it said the 4afe was out earlier that 90. maybe it's rare?
