Here's a dyno from Finland on a 7a-ge with small port head in a AE86. The 7a-ge is bone stock.
These are extremely close to the numbers we were projecting for our 7a-ge project back then. 93.1 kw @ 6380 rpm translates to 125 hp at the wheels. Add in the 14% driveline loss on RWD and you get a 143 hp at the crank. As for torque, 160.7 @ 4930 translates to 120 lbs of torque, plus the drive line loss which equals to 137 lbs of torque at the crank.
So 143hp and 137 lbs of torque. All this on stock components.
Our 7a-ge project had a ported head and 10.5:1 compression. Our estimate of 150hp is almost dead-on. So with some 264 or 272 cams, 160 hp would be a VERY possible item.
As for my 7a-gze project with the added SC14, we're expecting 200+ wheel HP and torque.
Pat
