Truth or Myth? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-10-2006, 04:43 AM   #1 (permalink)
AE101
View digital_racer's Photo Gallery
Truth or Myth?
I was told by a friend that touching the glass part of a halogen bulb will reduce its lifespan. Is it really true?
digital_racer is offline   Reply With Quote
Old 04-10-2006, 06:03 AM   #2 (permalink)
View Burger_AE102's Photo Gallery
This is generally true for a lot of bulbs. Halogen lamps in particular though, are succeptable to failure when touched with bear hands.
The oils that naturally occour on your skin will create an inperfection on the glass of the globe, which can become a weakness.
The solution is simple though, just change is with a clean cloth, or hold it by the base only, or wear disposeable latex gloves.. whichever suits.
Corolla, don't leave home without it.
Burger_AE102 is offline   Reply With Quote
Old 04-10-2006, 09:15 AM   #3 (permalink)
View Guido's Photo Gallery
Actually, the oils on your hands (or any other dirt or contamination) will cause the bulb to overheat, and this is what will shorten the life of the bulb.
It's not a problem with regular incandescent bulbs because they operate much cooler than halogens.
If you do get it dirty, wipe it clean with a kleenex and rubbing alcohol.
Guido is offline   Reply With Quote
Old 04-10-2006, 02:28 PM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
some will bubble where they were touched
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 04-11-2006, 02:13 AM   #5 (permalink)
Gameroom cash: $121755
ok... to put this accurately...
what happens is the oils from your hands get onto the glass.... when a halogen bulb is on, they do get really hot.... the oils on the bulb get much hotter, to the point where the glass can't handle the heat
either it will bubble (if you're lucky) or it will explode, and you will forever have glass in your headlight
1) 1990 Corolla "SR5", part silvia, 7age.... & more 2) 1986 MR2, "MK1.22" 91 5SFE/S54 swap 3) 2010 Corolla S 5-speed (the super nice/low mileage DD - wife) 4) 1998 Camry (the boring, high mileage DD - me)
Old 04-17-2006, 01:49 AM   #6 (permalink)
AE101
I tested a set of halogen bulbs that I have for quite some time. I'm not sure if I actually touched the bulb or from the humidity but it exploded within minutes of use. Now I will "forever have glass in my headlight".
It has always happened with the left headlight, usually cooking the plug/socket in the process. I got away with a useful plug/socket this time. I'm planning to have my electricals checked and if my wallet allows, I'll have my wires replaced to be sure that there are no short or grounding.
Maybe another late effect of the flood that happened almost 5 years ago.
The Truth about Capacitors cam2Xrunner Audio, Video, and Security - Tech 20 10-29-2005 02:48 AM
Need truth about Acetone... BlueFusion6851 General Discussion 6 05-24-2005 11:55 AM
ain't it the truth..? Razo-E Off Topic 13 05-08-2005 07:17 PM
the graduation speech your will never hear, because its the truth. [long] Ratko Off Topic 15 09-11-2003 02:22 PM
