Has any one Put a 4AGE Head on a Stock 7AFE? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-10-2006, 06:45 PM   #1 (permalink)
View toyloco's Photo Gallery
Question Has any one Put a 4AGE Head on a Stock 7AFE?
Has any one Put a 4AGE Head on a Stock 7AFE and then Ran some boost to it (either Turbo or Supercharger)? I have heard when Putting the Stock 4AGE head on the 7AFE Stock Bottom end it Lowers the Compression but no one has said by how much? So I am just curious since I could not find a past topic that answered this question I would ask staight out.
Thanks
toyloco is offline   Reply With Quote
Old 04-10-2006, 08:37 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
Are you asking because you've heard about it?? or because you've read about it?? yes its been done. search for "7AGE"
Old 04-11-2006, 12:05 AM   #3 (permalink)
Yes, I should say I read about it but no one has said they ran a Turbo or Supercharger after putting the stock 4AGE head on a 7AFE or at least I have not found a topic saying they did as of yet.
Thanks
Old 04-11-2006, 01:54 AM   #4 (permalink)
View AVANT's Photo Gallery
Boosting a 7age has been done, but I personally don't recommend much boost on it because the 7AFE rods are fairly thin.
1987 Corolla FX16 GTS. 4AGE powered.
AVANT is offline   Reply With Quote
Old 04-11-2006, 01:59 AM   #5 (permalink)
KDM is in
REN69's Avatar
like I said SEARCH! Rolla-pat from Montreal has ALREADY built a Supercharged 7AGZE that's running about 200+hp and he has a thread about it here and at dorikaze.com
Specs:
- 1.8 litre 7a-fe block oversized and decked
- 7a-fe crank with new oem bearings
- 7a-fe rods with new oem bearings
- 4a-gze US Spec 8:1 pistons 81.5mm oversized new OEM
- Estimated 8.8:1 compression
- New oem piston rings
- New oem head gasket
- 4a-ge big-port head, ported and decked
- HKS 264 intake and 256 exhaust cams 8.35mm lift
- homemade adjustable cam gears
- New oem water pump
- Shimmed new oem oil pump
- TRD thermostat
- 4a-ge big port NA intake and throttle body
- Complete oem gasket and seal kit
- Toyota Previa Van 2tz-fze SC14 1435cc supercharger with 125mm SC12 pulley
- Blitz Dual Drive Blow-off valve
- 7m-gte front mount Intercooler
- 7m-gte 440cc injectors
- Venom High Flow 3s-gte fuel pump
- AE101 gze turbo pressure sensor OEM
- AE101 gze ECU
- AE101 Crank sensor
- AE101 gze coils packs
- 7m-gte igniter
- Denso Iridium IQ24 Sparkplus @ 0.032
- E-manage piggyback unit with injector harness and Greddy map sensor 3 Bar
- Custom coolant piping
- Custom intercooler piping
- Custom wiring
- Custom engine mounts and accesory brackets
- New oem belts
- HKS Crank pulley with dampener
- K&N air filter
- Twincore OEM Toyota radiator made to fit
- Trimline Flexalite electric fan with home made relay
- ACT clutch kit (pressure plate, clutch) good for 277 lbs of torque
- 2.5" exhaust piping
- Hi-Flow Dynomax catalyst
- Hi Flow Dynomax 3 pass exhaust
Pat
http://www.toyotanation.com/forum/forumdisplay.php?f=69
7AFE head into an '89 4AF block help please |PuNiSh3R| 6th Generation (1988-1992) 46 03-25-2008 11:44 AM
4af to the fe head? or 4age internals in a 4af? freakinbox Archived Corolla threads 24 04-07-2006 02:21 AM
4age JDM head Project86 Archived Corolla threads 9 10-07-2004 11:08 AM
7afe head convertion 93corollaracer Archived Corolla threads 5 08-21-2004 09:57 AM
