4a-fe wierd stuff - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-12-2006, 11:25 PM   #1 (permalink)
View phishy's Photo Gallery
4a-fe wierd stuff
'92 corolla all-trac wagon. the motor jumps around quite a lot at idle, and I'm sure I needs at least one new motor mount but it also seems to run a little rough.
Checked the plugs and wires, and when i take off the third cylinder wire - nothing happens. All the other three make it drop and run like crap, but nothing changes with the third. The wire arcs fine and the plug is functioning. The injector is fine (checked resistance and get voltage on the connector too). I will do a compression check, but I'm waiting to borrow a tester that's long enough to get into the plug hole. Even with a burnt valve, i would think that it should affect the running condition somewhat when one cylinder is disabled...
Sorry to ramble but I'm at a real loss here . Could really use some help/ideas....
Cheers
phishy is offline   Reply With Quote
Old 04-13-2006, 12:29 AM   #2 (permalink)
View tashirosgt's Photo Gallery
Can you check the timing? Another thought is whether you can hear the injector work. If you put something like a short length of broom handle against the injectors and listen at the other end, they make a distinct sound when they fire. Let us know how the compression test comes out. This is interesting.
tashirosgt is offline   Reply With Quote
Old 04-30-2006, 01:44 AM   #3 (permalink)
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
Do the mount first as this sounds like the prob...
Then a basic sevice
eg plugs , air fiter, fuel filter that sould take care of the prob
hope this helps
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
Old 04-30-2006, 01:48 AM   #4 (permalink)
cuzman's Avatar
Check ya dizy works and the cap has no sings of wear or cracks
Leads last bout 10,000 miles tops as far as im concerned..replace if possible
ps sorry bout the second post
Old 05-08-2006, 04:09 AM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Check the resistance of the spark plug wire and see if its within spec.
Old 05-08-2006, 02:12 PM   #6 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
I found that the cheap aftermarket plug wires suck and don't last long.... also a carb with a lot of mileson it and/or out of adjustment can cause the engine to dance and run like crap...
But, you don't give a full description of exactly how the engine runs,, under all conditions so I can't go on any more..
retiredat44 is offline   Reply With Quote
Old 05-09-2006, 02:55 AM   #7 (permalink)
cuzman's Avatar
The engine mount behide the radiator is pron to breaking...try that!
If its busted it will only be obvious one removed!
Or get a mate to rev the engive or load it upo a little while watching
look for cracks/breaks in the rubber
Old 05-12-2006, 04:03 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Then take poly urethane mass (not the foam stuff) and fill the mount for solid Poly urethane mounts.
4a fe head on 4age block fleetwood dicki Hardcore Tech and Competition 3 02-15-2005 12:03 PM
