What is this on my carb? It gets really hot!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2006, 10:05 AM   #1 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
My car won't idle; ever. It bogs down to 400rpm and shakes violently, not matter what I set the idle screw at.
Anyways, that might be a whole different issue. But, what is this thing on my carb? It gets REALLY hot (as in the metal on it will burn you) so it is obviously shorting out!
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Old 04-15-2006, 04:43 PM   #2 (permalink)
View karazy's Photo Gallery
It's hard to tell from the pic, but it looks like the choke. If it isn't working right, you won't get it to idle.
karazy is offline   Reply With Quote
Old 04-15-2006, 06:51 PM   #3 (permalink)
omg jdm
aaron7's Avatar
Hmmm... that might be the reason I can't idle and it wreaks of gas all the time...
Old 04-16-2006, 07:57 AM   #4 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
There is an electric element inside the housing you circled. It is used to gradually heat the bi metallic spring to open up the choke butterfly . It is a normal condition and thats why the housing feels hot.
90 GP is offline   Reply With Quote
Old 04-16-2006, 11:54 AM   #5 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
Originally Posted by 90 GP
There is an electric element inside the housing you circled. It is used to gradually heat the bi metallic spring to open up the choke butterfly . It is a normal condition and that's why the housing feels hot.
Its an automatic choke, and has a clock like spring in it, as 90 gp said as it heats up it slowly opens your butterfly...Should have screws on the cover that once you loosen then you can adjust how fast you want the butterfly to open by turning it ether way...The ones I saw had arrows pointing each way saying "richer or leaner" and you hand adjusted...good luck...~Radd
Raddman is offline   Reply With Quote
Toyota Corolla Carb Rebuild retiredat44 General Discussion 3 03-19-2006 04:36 AM
'86 SR5 Carb & Choke Quandary ARCHINSTL Tercel, Paseo, Starlet, and Sera Forum 1 07-03-2005 07:17 AM
Scion VIP @ Hot Import Nights - Boston - April 30, 2005 ScionVIP Scion Events 3 04-11-2005 02:16 PM
