New Wheels For AE92 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-16-2006, 04:19 PM   #1 (permalink)
View Hoggie4th's Photo Gallery
AE92 New Wheels For AE92
Im looking for new wheels for my 90 ae92, not shure how wide to go, i want to get all the way out to the lip of the fender if possible. post your thoughts and past experiances.
-C
So far im looking at the Axis Reverb
Hoggie4th is offline   Reply With Quote
Old 04-16-2006, 05:50 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
did you do a search.. this is a topic that has been brought up way too many times already. \
14x7 offset 38-45mm - good for competition/daily driving.
15X7 offset 38-45mm - good for competition/daily driving.
16X7 offset 38-45mm - still does the job
17s are overkill.. stick to 16 max.
if you use 205width tires, you might have to use spacers on the back wheels depending on the offset as they may rub your struts.
Old 04-16-2006, 09:08 PM   #3 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
my or52 enkie's (16x7) are GREAT! . but the 205 45 tires rub on the inside rear because of that extra rubber lip on the tire to protect the rim... but other than that the rim doesn't rub
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 04-16-2006, 11:21 PM   #4 (permalink)
View epyon22's Photo Gallery
what about 205's on 15's do you think they will rub? i was thinking of running some azenis on my 15x7's when i get them. every thing is offered in 205 not 195 also
'89 ae92 GT-S bought brand new dec '88
http://photobucket.com/albums/v227/epyon22/car/
epyon22 is offline   Reply With Quote
Old 04-17-2006, 04:30 AM   #5 (permalink)
Vroom?
freakinbox's Avatar
the only reason mine rub is because of that extra lip on the tire but that depends on the offset... a 205 is a 205 on a 16 inch or a 15 inch rim...
Old 04-17-2006, 07:33 AM   #6 (permalink)
KDM is in
REN69's Avatar
The only reason yours rub is probably the offset and the fact you don't have spacers.
I ran 15x7 with 45mm offset for the longest time.. the tires at the back were close to rubbing and on the front they rubbed ONLY when I turned all the way to one side.. I ran 195 width though, had I run 205 width I would have needed spacers. I have a pair of spacers that I'm saving for when I run 205/50-15s.
On the AE92s, 45mm is probably the max offset you can run in the higher end and not rub the inner parts (fender or struts) and I'd say maybe 38mm the min offset you can run on the lower end.. maybe a tad lower without rubbing the outer fenders. The OEM GTS wheels are 39mm offset 14x5.5 and the MR2 wheels I believe are 38mm offset.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 04-17-2006, 02:52 PM   #7 (permalink)
Danno
View 89yotarollagts's Photo Gallery
15"/50/205's with 5mm spacer/ also longer and much stronger studs for both front and rear !! this is the way to go man !! the wider stance in the rear and the fatty looken tires looks and handles awsome ! plus its much more comfy ride with wider tires
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
Old 04-17-2006, 03:42 PM   #8 (permalink)
im looking at 38mm offset is that good enough for 205's with out spacers you think?
Old 04-17-2006, 04:34 PM   #9 (permalink)
KDM is in
REN69's Avatar
You might not even need the spacers for that offset, check it out first.
Old 04-18-2006, 09:04 AM   #10 (permalink)
View browner's Photo Gallery
16x7.5 is the size of my summer rims. I forget the offset but spacers are needed for the rear. I just ordered 15mm spacers with the wheel studs built right into the spacers.
browner is offline   Reply With Quote
Old 04-18-2006, 09:19 AM   #11 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
That's what I have and when I put them on they rubbed the inside of the rear fenders when the suspension bottomed. I filed down the inside fold on the fenders and now it's fine.
In any case it doesn't really matter, cause I'm not talking about AE92, but just saying, they could also rub the other side (not just the strut) if you have too-wide tires and too-low offset.
Edit: looks like the fenders on AE92s are more flared anyway, so it shouldn't be a problem
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 04-18-2006, 03:05 PM   #12 (permalink)
Vroom?
freakinbox's Avatar
my 16/7 rims have a 42 offset... the rim doesn't rub on the rear
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 10:53 PM
rim manufacturers? fireman9170 2nd Generation (2005+) 6 02-19-2006 11:05 AM
