60psi for tires?!? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2006, 02:24 AM   #1 (permalink)
View dwikiz's Photo Gallery
60psi for tires?!?
93 Prizm
Inside the glovebox theres a sticker that says the recommended tire pressure is 60psi. That seems incredibly high! I first chceked the door jamb for recommended pressure but its not listed there, the only place its listed is on the sticker in the glovebox.
Does this sound at all right?
dwikiz is offline   Reply With Quote
Old 04-17-2006, 03:16 AM   #2 (permalink)
The TN Member
View punter's Photo Gallery
60psi would be a maximum. put 30~34 psi in your tyres
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 04-17-2006, 04:31 AM   #3 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
depends what your going for. and on the tire's max. If your looking for preformance play around with the tire pressure
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 04-17-2006, 05:01 AM   #4 (permalink)
View karazy's Photo Gallery
Are you sure it wasn't for the space saver spare? 60PSI is way too high for the others.
karazy is offline   Reply With Quote
Old 04-17-2006, 05:58 AM   #5 (permalink)
View arens's Photo Gallery
Yep, I bet that is for your spare tire.
I haven't even seen any passenger car tires that show 60psi in their range. Most show a max cold pressure range between 35 and 44psi. There are a few that are up to 51psi. I only know of a few truck tires that get up to 60 or 65psi for cold tire pressure.
arens is offline   Reply With Quote
Old 04-17-2006, 06:14 AM   #6 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
With 60 psi in a normal car tire you'll be lucky if they dont explode when you hit a pothole. I agree...the 60 psi is most likely for the spare.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 04-17-2006, 08:06 AM   #7 (permalink)
Gameroom cash: $232150
View Joe B's Photo Gallery
60Lbs is the recommended pressure for the compact spare only.
'11 Camry Hybrid Classic Silver/Ash
Moonroof | NAV | Leather | JBL Audio | XM | Blue Tooth | OEM Remote Start | Michelin Primacy MXV4
'11 Honda CR-V EX-L w/NAV 4WD Glacier Blue/Gray
Leather | Remote Start | Fogs | Premium Sound | XM | Wood Dash | Michelin Primacy MXV4
Joe B is offline   Reply With Quote
Old 04-17-2006, 10:56 AM   #8 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
Yeah, sounds like it's for the spare.
You should definitely put no more than it says on the tire wall.
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 04-17-2006, 08:35 PM   #9 (permalink)
View Maxpayne124's Photo Gallery
60psi is definetly for the spare. had a guy come into the dealership, about 26,000km on it. complaning about a clunking from the front. put the car on the hoist and took a look at the struts and both front were blown, checked tire press. was at 65psi and the tires were wearing out very very bad in the middle
780tuners.com
corollacustomz.ca
toyotanation.com
Maxpayne124 is offline   Reply With Quote
