Originally Posted by REN69
why would they have to sell you an entire set of rims if you want 185/60-14????
It's not that they don't want to put 185/60/14 on the rims I currently have. I need new set of rims, so that I won't have to swap summer and winter tires on the same rims, but instead just swap the wheels. Swapping wheels is a lot easier and cheaper
than changing just tires, which requires balancing.
Originally Posted by Ukrainian102
The profile does not change unless you get larger wheels.
True, the amount of rubber in millimeters is the same, but the aspect ratio (height/width) is smaller, so I wonder if that would make any noticeable difference.
