speedometer died, OD light blinks???? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2006, 08:39 AM   #1 (permalink)
View tonyvt's Photo Gallery
So Im climbing a hill. All of a sudden my Corolla starts shifting eirraticly. Heres the deal. The speedometer does not work, the OD light blinks on and off and it does not shift correctly?
Any ideas? Any chance resetting the ecm (remove battery cable) could help?
95 Corolla automatic
145000 miles
Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
tonyvt is offline   Reply With Quote
Old 04-17-2006, 09:05 AM   #2 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
The car does that when it is in diagnostic mode, i.e. there is a connection between diagnostic terminals. Look under the hood, pop open the diagnostic box (small plastic box by intake pipe) and make sure there's nothing connecting the terminals in there.
Most likely there won't be anything in there, and hopefully resetting the ECU should do the trick.
Just disconnect your battery cable for like 10 min (enough for the reserve charge to die) and then hook it back up.
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Consumer Reports on HID Phi General Discussion 28 01-17-2007 08:23 PM
piaa vs stock ProjectCorolla Archived Corolla threads 37 02-28-2006 06:08 AM
Brake light warning icon abovethelaw Camry & Solara Lounge 7 02-22-2006 03:53 PM
Rear Warning Light Problem dtmolt Camry & Solara Lounge 3 01-22-2004 01:38 AM
'95 Camry XLE with oil light/ speedometer issue aeonnfluux 3rd & 4th Generation (1992–1996 & 1997–2001) 6 06-27-2003 09:53 AM
