60k maintenence - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-18-2006, 09:11 PM   #1 (permalink)
View hadadat's Photo Gallery
60k maintenence
Hey Everybody,
Been lurkin the forum here for some time, made a post or 2, and its time for another.
I have an 03 S. I bought it 1 year ago today with 33k on it, now it has 60k. So quite a few miles. Is there any crucial maintence I should consider at the 60k mark? I change my oil every 3k on the dot, and replaced the AEM air filter at 55k. Should I consider a tranny flush? (Its manual). New belts? Any help is appreciated, I feel that since my car is under warranty I cant get a straight answer from the dealership. Thanks again
hadadat is offline   Reply With Quote
Old 04-18-2006, 09:32 PM   #2 (permalink)
View 03mooncorolla's Photo Gallery
Info from http://smg.toyotapartsandservice.com/owners.php
Do a service history on the VIN at your local dealer they can tell what's been done to it before you purchased it. (but with 30000miles since you bought, the service they recommened is most likely required. "coolant")
2003 Corolla
60,000 Miles - 48 Months
Replace engine air filter Replace engine coolant Replace engine oil and oil filter Rotate tires Inspect the following:
Ball joints and dust covers Brake lines and hoses Brake linings/drums and brake pads/discs Differential oil Drive belts 4 Drive shaft boots Engine valve clearance Exhaust pipes and mountings Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses Fuel tank cap gasket Radiator core and condenser Steering gear box Steering linkage and boots
Transmission fluid or oil.
03mooncorolla is offline   Reply With Quote
Old 04-18-2006, 09:43 PM   #3 (permalink)
New 2006 Corolla LE owner
View ToyotaMan1281's Photo Gallery
this is one of the big maintenance times. Check your owners manual it will tell u what has to be done.
Toyota 4 life!!
ToyotaMan1281 is offline   Reply With Quote
60k CEL[Check Engine Light] SnakeyeS Camry & Solara Lounge 10 10-13-2006 09:42 PM
60K Mtce cam01speak Camry & Solara Lounge 3 10-04-2005 03:20 PM
60k maintainance suggestions toydon Camry & Solara Lounge 6 08-09-2005 02:10 AM
'01 Camry I-4 AT 60k service ssolomo 3rd & 4th Generation (1992–1996 & 1997–2001) 2 07-07-2004 09:08 PM
Gen 3 60k tune up Studious 3rd & 4th Generation (1992–1996 & 1997–2001) 3 02-22-2004 02:02 PM
