2000 1.8L engine overheating - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2006, 03:11 PM   #1 (permalink)
View Robert K's Photo Gallery
A friend has a 2000 Corolla with 1.8L engine. The car is overheating because the cooling fans on the radiator will not come on. We wired the fans straight to the battery to check them and they worked fine. All of the fuses also appear to be okay as well. Does anyone know how the fans are activated? I would assume that there is a sensor on the block that possibly activates a relay. Is this correct? If so, where is the location of these parts. All help is welcomed.
Grace and peace,
Robert K
Robert K is offline   Reply With Quote
Old 04-20-2006, 05:45 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Its not overheating because the fans don't come ON, its overheating becasue either A. your thermostat is dead and stuck and therefore the temp sensor doesn't get the right temp reading to turn the fans on, OR B. your temp sensor is dead and of course that's the reason why the fans don't come ON, because the temp sensor is not triggering them.
Old 04-20-2006, 07:13 PM   #3 (permalink)
The TN Member
View punter's Photo Gallery
If you hard wire the fans on like you said you have, does it overheat, try that out.
If it still overheats then your themostat is stuffed, if its doesn't overheat then the thermo switch or fan wiring is broken.
Try that and let us know what happened. Also you might want to check your water pump.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
2000 camry engine problems help? LONG jotka 3rd & 4th Generation (1992–1996 & 1997–2001) 10 03-24-2006 10:16 PM
'2000 Avensis 1.8 VVTi - engine? Aven71 General Discussion 1 02-14-2005 05:17 PM
Engine swap? Up to the 1.8L? lethal_force Scion Forum 12 05-26-2004 09:41 AM
Just got a 2000 Toyota Celica GT, Looking for Engine Swap Tantalis Hardcore Tech and Competition 5 09-10-2002 04:01 PM
