Door lock trouble - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2006, 03:41 PM   #1 (permalink)
View green_raider's Photo Gallery
USA Door lock trouble
Alright here is my problem...
I have a 96' Toyota Corolla DX with power locks, and the car has been doing very well, until last night when i tried to lock my car with the power locks and all the doors except for the back door left hand side, I just want to know what could the problem be.
James
rolla 4-ever
Toyota 4-ever
green_raider is offline   Reply With Quote
Old 04-20-2006, 04:20 PM   #2 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
Does it still make the "lock sound" form the door when you press the lock button? Does the lock move at least a little bit?
If so, you just need to take off the door panel and spray WD-40 all over the lock mechanism.
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 04-21-2006, 12:58 AM   #3 (permalink)
Cressida nut
Gameroom cash: $251045
View kamesama980's Photo Gallery
lihtium white grease works well and will stick around. WD40 will run off and evaporate quickly. use one then the other.
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'90 Suzuki VX800
"You don't get to judge me for how I fix what you break"
kamesama980 is offline   Reply With Quote
Old 04-22-2006, 10:03 AM   #4 (permalink)
Ghostridin the whip
Is it a spray thing or a grease sort of thing? When you open the door panel the lock mechanism itself is hard to see and reach, so to spray it you need to use the little extension straw that you stick in the spray can.
I know there's better stuff than WD-40 but for me it seems to do the trick.
Old 04-24-2006, 11:31 PM   #5 (permalink)
The door lock does not make a sound I checked everything the lock does not move at all I think it might be the door lock actuator, also my other door lock on the opposite side is not moving very much should I try the greese suggestion? thanks for the help
Toyota 4-ever
Old 04-25-2006, 10:01 PM   #6 (permalink)
519
Custom User Title
519's Avatar
View 519's Photo Gallery
yeah try greasing up the rear passenger door first.
'99 Corolla VE
*If you're having car problems, I feel bad for you son...*
*I got 99 Problems but my toy ain't one.*
519 is offline   Reply With Quote
Old 04-25-2006, 10:14 PM   #7 (permalink)
Ghostridin the whip
If it's not making the sound or moving at all it might be the actuator. Try the grease suggestion on the other one if there is a sound and it moves a little.
If you need to replace the actuator, don't get a new one... you could probably get one from a junkyard much cheaper.
Old 04-27-2006, 07:28 PM   #8 (permalink)
Thanks for all the help i'll try to look for an actuator at the junk yard and i'll try the lithium grease
James
Toyota 4-ever
Galaxy 5000RS-2W Car Alarm Installation Trouble JavaFanatic Audio, Video, and Security - Tech 8 07-31-2008 01:10 AM
trouble, trouble and trouble with 3vz-fe gbaoyn Camry & Solara Lounge 13 04-20-2006 09:26 PM
93 Corolla stereo self install - worth the trouble? SkyeW4 Audio, Video, and Security - Tech 13 09-04-2005 07:16 PM
Crankshaft pulley trouble... BIG BIG TROUBLE!! and little bit of reading... _VVTi_ Camry & Solara Lounge 12 06-18-2005 09:20 PM
Having trouble with alarm system in 2000 Camry LE JavaFanatic 3rd & 4th Generation (1992–1996 & 1997–2001) 9 03-12-2005 12:16 PM
