Valve Noise?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2006, 05:28 PM   #1 (permalink)
View barthmonster's Photo Gallery
Valve Noise??
Have a problem 1991 (4afe) Corolla, and I need help. I have valvetrain noise after warmup, but not before. I put a shortblock into this car and only cleaned the cams up a little and re-installed them. I measured all valve clearances last night and they are as follows:
(Intake spec: .006-.010 in.
Exhaust spec: .008-.012 in.)
in thousanths, all intakes: 7,8,8,8,8,9,8,9
in thousanths, all exhausts: 10,11,9,10,11,11,10,10
Since many of these are near the max spec, could this be why I'm hearing it when warm but not cold?? Don't the valves 'lengthen' when hot and the clearance goes down, so it should be quieter ??
I could have also messed up the Intake Cam '2-piece gear' pre-load too I've heard, but don't know if that was the problem, why it would be quiet when cold.
Thanks a ton for your help guys. The books just don't have some stuff, ya know?!
barthmonster is offline   Reply With Quote
2005 LE valve noise AustinA35 5th & 6th Generation (2002-2006 & 2007-2011) 2 03-27-2006 03:17 PM
I have valve noise or some funny rattle- 03 Highlander V6 30k miles SILVERROLLA 1st Generation (2001–2007) 5 01-07-2006 09:36 PM
PCV valve is screwed up... I helped it.. 4EVERCooL 1st Generation (1995-1999) 3 11-14-2005 07:55 PM
'88 Corlla Valve noise? excelent3 Archived Corolla threads 8 01-18-2005 08:37 PM
