Ok time to get new rims wondering if these will fit. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2006, 03:45 PM   #1 (permalink)
Mr. Nice Guy
canadianae92's Avatar
View canadianae92's Photo Gallery
Some sport max wheel thats cheap for 139 each wheel, 15x8 32 offset 4x100 bolt will it fit?
or Konig rewind FWD 4x100 42 offset and 15x7 will it fit? Thanks guys..
1991 Corolla GT-S
canadianae92 is offline   Reply With Quote
Old 04-21-2006, 04:31 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
The sportmax is nice.. the rewinds, if you can find them.. are FTW!
32 offset on the sportmax sounds a little too tight.. the Rewinds with 42 offset are a better, safer choice.
Remember.... AE92: 38-45offset... 38-45offset... 38-45offset...
Old 04-21-2006, 04:47 PM   #3 (permalink)
cinnabar's Avatar
View cinnabar's Photo Gallery
I stuck some 17x7 on my 97. ASA JS1... lemme say they're sweet! I did have to put some stiffer struts in though, the stocks were trash. In some instances, not mine, the larger wheels have a tendency to rub, esp. on the rears. Easily fixed by bending the inside lip of the wheel wells up. Sounds scary but you can't see the mod from the outside.
Get R Done
cinnabar is offline   Reply With Quote
Old 04-21-2006, 09:36 PM   #4 (permalink)
Mr. Nice Guy
Ok got it, 38-45 offset 38-45 offset 38-45 offset.
Old 04-22-2006, 10:27 AM   #5 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
Yep, fat tires with a low wheel offset will rub in the back on 93-97. Instead of bending that lip up I just filed it down and painted over it.
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 04-22-2006, 03:45 PM   #6 (permalink)
Mr. Nice Guy
My stock rims/ tires already rub during hard cornering need stiffer springs and front sway bar..
Old 04-22-2006, 03:48 PM   #7 (permalink)
KDM is in
REN69's Avatar
probably springs and struts.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 04-23-2006, 09:38 AM   #8 (permalink)
cinnabar's Avatar
yeah, canadianae92, mine does the same thing when I put on the new wheels. I put some tokico struts in which solved most of the rubbing at higher speeds but I still get it when cornering, and its even worse if its an uphill turn. For the life of me I still can't find stiffer, normal length springs without getting the lowering type. Damnation.
Get R Done
Old 04-23-2006, 02:13 PM   #9 (permalink)
View 94_Rolla_Guy's Photo Gallery
im running 16x7 40mm and apex 1.6" with KYB GR2's i had to roll the fenders up to keep them from rubbing
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 04-23-2006, 03:54 PM   #10 (permalink)
Mr. Nice Guy
Would anyone happen to have pictures of fwd konig rewinds(other than the ones from konigs web site).
For suspension I want to get GC coil overs with stiff springs I don't know how stiff stuff like lowering springs would be.
Old 04-23-2006, 08:51 PM   #11 (permalink)
View epyon22's Photo Gallery
http://www.ae92gts.com/ae92gts_wheel_fit.html<< great ae92 wheel guide
for ground control you can tell them the application that you want to run and they will choose the stiffness. i told them a mix between street and autocross and they gave me 250 lbs in the rear and 300 lbs in the front
'89 ae92 GT-S bought brand new dec '88
http://photobucket.com/albums/v227/epyon22/car/
epyon22 is offline   Reply With Quote
Do these fit? 16" X 7" rims on a 96 XLS? 96AvalonXLS 1st Generation (1995-1999) 1 04-25-2005 05:29 PM
What other toyota rims will fit? VR6_CHRIS Camry & Solara Lounge 4 11-03-2004 09:22 AM
would these size rims fit on my Gen 2? crazy_camry 1st & 2nd Generation (1983–1986 & 1987-1991) 21 05-13-2003 10:22 PM
What years of corolla rims will fit on Celica? Den Archived Corolla threads 10 03-02-2003 01:07 AM
BMW bolt pattern rims to fit on an IS 300?? V6LE General Discussion 8 10-31-2002 02:29 PM
