Ae92 Oil Leakin - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2006, 01:24 AM   #1 (permalink)
View Fang50's Photo Gallery
AE92 Ae92 Oil Leakin
I recently overhawled my engine, as my rear main seal was busted. Replaced rings big end and mains, as well as replaced sump as it had minor cracks. After doing the motor, I now have a problem whereby if I drive the car hard...the engine seems to push out oil through the every seal on the tappet cover. It seems like the engine is building up pressure. It alos tends to pop out the dip stick as well...and then I have oil all over the engine...It is a 4AF motor, standard carburettor.
Please any infor to resolve this problem will be grately appreciated
Fang50 is offline   Reply With Quote
Old 04-25-2006, 02:16 AM   #2 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
was everything toqued proper? or are the seals all sitting proper?
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 04-25-2006, 02:27 AM   #3 (permalink)
View tashirosgt's Photo Gallery
Some possibilities, from minor to major.
Is the oil level too high? One can check the level on the dipstick, but is it the OEM dipstick? An aftermarket dipstick might not be calibrated correctly.
Is the PCV valve clogged? ( On m '89 it's a gray plastic valve that plugs into the valve cover. ) If the valve is open, is the tube it goes to clogged?
Could the ring job have gone bad? A compression test should show this. You should probably do this test after a rebuild, whether you have a problem or not.
I'm trying to visualize what would happen if a oil channel got plugged or covered by a mis-installed gasket. But I don't have a good concept of the circulation of the oil in that engine, in spite of having taken one apart. Anyone know how to detect this kind of problem? I've accidentally overfilled a 4A-FE with oil before. The head made a slush-slush-slush sound like a washing machine! However I quickly corrected the problem and the engine runs fine.
tashirosgt is offline   Reply With Quote
Old 04-25-2006, 03:16 AM   #4 (permalink)
Post
Thanks for the reply...
The dip stick is oem...oil level is correct ...except that I have to keep checking as it kicks out allot of oils...so top ups are regular...compression was tested and seems to be ok...as for the PVC valve have not check that one yet...will check that and take it from there...the ait filter seems o be really filled with oil...and this causes my car to smoke allot as well...
Let me take it step by step and start with the PVC valve, first and then see wht to do next
Regards
Fang
Old 04-26-2006, 12:32 AM   #5 (permalink)
AE92
Hey guys....
much happier today...stripped da PVC valve...working ok....dnt no wht make me check the breather pipe as well....found out that the idiot mechanic who did the car stuff some sort of wire gause down it, so that got blocked....cleaned it out and motor seems better...drove it real hard this morning...6000 rpm + and seem to be fine...no oil from da Tappet cover ...replaced the air filter while I was at it...as it was soaked with oil as well....just need to burn out all dat access oil sittin in my exhaust, and on my carbs....
thnx for da help guys...really appreciated it
Fang
Synth. Oil Change Interval? Phi Hardcore Tech and Competition 46 09-18-2007 10:00 PM
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 12:26 AM
Synthetic Oil KingofDiamonds General Discussion 32 01-08-2006 08:38 PM
1990 N/A Auto :( dave_id Supra Forum 6 08-26-2004 12:18 PM
Better Oil filter for Camry TRDragoon Camry & Solara Lounge 44 12-08-2003 02:38 PM
