2000 Corolla- Burning Oil :( - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2006, 03:36 PM   #1 (permalink)
View miklebud's Photo Gallery
Okay, I just bought this car 3 weeks ago and didnt really notice the fact that it's burning oil at an uncomfortable rate. Any suggestions on what it may be?
2000 Corolla LE Automatic
97000 miles
I've changed the oil 3 days ago, put 3.9 quarts and a fresh Toyota oil filter in. I also took out the PCV valve and cleaned it out. The PCV valve was a-okay, it rattled like it should.
There are clouds of blue smoke as well as a smell of burning oil under the hood. I've driven 180 miles and the oil level on the dipstick has gone down a quarter of the way between the fill line.
What are the common problems with these engines? Thanksfully it's under warranty for another 10 days, so I'll just hope they'll be able to deal with it.
Headgasket?
Valveseals?
miklebud is offline   Reply With Quote
Old 04-25-2006, 06:33 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Not neccesarily burning it.. I had a leak in my oil cooler lines one time, everytime I stepped on the gas.. oil would spurt out of the cooler line and onto the manifold, leaving a nice smoke cloud behind me and the same oil smell in the engine compartment. I'd say look for oil leaks, specifically ones that are dropping oil on the manifold OR the exhaust system in general.
Old 04-25-2006, 06:37 PM   #3 (permalink)
rwd_3tc
View rwd_3tc's Photo Gallery
on the 2000 corolla its not the head gasket. it need a new block. or piston rings. i know this cause we had lots of these at the dealership
rwd_3tc is offline   Reply With Quote
Old 04-25-2006, 08:34 PM   #4 (permalink)
There are no leaks evident on the block. The blue smoke is coming out of the exhaust pipe. There are no leaks visible in the engine bay, or on the ground underneath the car. I'm really hoping it's not something that requires taking apart the engine, if that's the case, I dont want the car. I bought a Corolla so I wouldnt have to worry about things like this...
Old 04-25-2006, 08:41 PM   #5 (permalink)
The TN Member
View punter's Photo Gallery
At a guess, oil control rings. That means pulling the engine apart.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 04-25-2006, 09:34 PM   #6 (permalink)
Well, F that. Good thing it's under warranty for another 10 days.
Old 10-08-2006, 10:34 AM   #7 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
It means pulling the engine apart, but at least rings are relatively easy to do.
diver9000 is offline   Reply With Quote
Old 10-08-2006, 10:57 AM   #8 (permalink)
Bitter's Avatar
Gameroom cash: $559600
View Bitter's Photo Gallery
yep, you're not the only 98-2000/20002 1ZZFE corolla owner thats had piston ring issues like this.
Old 10-08-2006, 11:07 AM   #9 (permalink)
diver9000's Avatar
whats a deleted intake snorkel?
Old 10-08-2006, 12:04 PM   #10 (permalink)
Bitter's Avatar
that little snorkel that runs from behind the headlight and then squeezes under the battery tray, that came out because i dropped a bolt down it. well i never put it back in and it turns out that removing that peice made a large difference in the zoomyness of the car.
Old 10-08-2006, 02:04 PM   #11 (permalink)
View tnmk's Photo Gallery
If you got warranty demand that they take care of it. Don't let them blow smoke up your *** (pardon the pun)
I had a car once that had a slightly rough idle (relatively low miles) when I test drove it and the salesman said probably from sitting for while, should smooth out. Well it didn't. I had to go back several times but finally they found that I had a cracked ring and bent rod. But I had to keep on them to get it fixed.
Go back and get it fixed!
tnmk is offline   Reply With Quote
Old 10-08-2006, 02:45 PM   #12 (permalink)
View toyomoho's Photo Gallery
My guess is rings/scored cylinders. It is very possible for an engine to burn a LOT of oil and not have any obvious signs. If you have blue smoke, the burning rate can be even higher.
Find out if this engine has hardened cylinder walls. If so and you need to bore them, the rebuilt engine may not last as long.
Old 10-08-2006, 05:55 PM   #13 (permalink)
diver9000's Avatar
Hey at least you've got a warranty. Dont let them make you run it out past the warranty so you get stuck having to pay for it. Make sure you get it in to them and get it on paper before the deadline.
2000 corolla using oil whitcre Archived Corolla threads 9 12-19-2006 05:57 AM
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 12:26 AM
2007 Camry pictures Meet Joe Asian Toyota News 919 01-09-2006 01:42 PM
Does 2000 Corolla Ve has a timing belt? John2000ve Archived Corolla threads 5 02-03-2005 11:44 AM
VVT-i oil burning LOST Celica Forum 1 02-04-2004 03:52 PM
