fender rolling - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2006, 09:21 PM   #1 (permalink)
View Maxpayne124's Photo Gallery
fender rolling
anybody know a shop that rolls fenders? just put on my new rims and tires and since its lowered as well, through bumps and hard turns, the rear fenders will rub against the tires. the tires i just bought are falken azenis rt-615 which cost about $300 a piece (only performance tire i could get in the size i needed). if no shops around, anyone got a procedure for doing it themselves? thanks a bunch
780tuners.com
corollacustomz.ca
toyotanation.com
Maxpayne124 is offline   Reply With Quote
Old 04-25-2006, 09:47 PM   #2 (permalink)
519
Custom User Title
519's Avatar
View 519's Photo Gallery
Here is one for a do it yourself project
Vamp's Domain: Rolling the Fenders
'99 Corolla VE
*If you're having car problems, I feel bad for you son...*
*I got 99 Problems but my toy ain't one.*
519 is offline   Reply With Quote
Old 04-25-2006, 10:08 PM   #3 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
What car, what size tires, what wheel offset?
Sometimes you can file the fenders down instead of rolling them if it's only rubbing a little on the sidewall of the tire.
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 04-25-2006, 10:16 PM   #4 (permalink)
1995 corolla 1.6l with Eibach pro-kit, motegi 15" mr-7 with +35 offset, tires are P205/50 R15 falken azenis rt-615
780tuners.com
corollacustomz.ca
toyotanation.com
Old 04-25-2006, 10:30 PM   #5 (permalink)
sxlostv1's Avatar
View sxlostv1's Photo Gallery
your offset is too wack. for corolla, offset is optimal between 40-45 on 15x6.5
sxlostv1 is offline   Reply With Quote
Old 04-25-2006, 10:55 PM   #6 (permalink)
Ghostridin the whip
Shit 35 offset with 205s is nasty...
I have 38 with 205s and they rubbed on the inner lip of the fender in the back, so I filed down a bit of that inner lip and painted over it.
I dunno how much yours rub... probably quite a bit more, especially with the drop. Does it rub the actualy top of the tire (you're gonna need to roll them), or just the sidewall (possibly could file down the fender or use a Dremel)?
P.S. Also just noticed... are you running Eibach Pro-Kit with stock struts? It's really no good for your struts and if you change for stiffer ones you'll rub less, although that won't solve the problem entirely.
Old 04-25-2006, 11:39 PM   #7 (permalink)
ya im running on stock stuts (for the time being) but its rubbing on the sidewall area towards the top
780tuners.com
corollacustomz.ca
toyotanation.com
Old 04-26-2006, 03:21 AM   #8 (permalink)
View Fang50's Photo Gallery
Thumbs up
I had the same problem on my AE92...rolla...took a grinder and cut slits into the fender arch and just knocked it back with a rubber mallet...works well....and this way the paint work does not crack when u bend it back...
Fang50
Fang50 is offline   Reply With Quote
Fender rolling DIY augcam Camry & Solara Lounge 12 08-16-2005 04:35 AM
Bent rear fender: need ideas to straighten (PICS ADDED) dcomma2002 Archived Corolla threads 6 05-28-2005 11:10 PM
How do I remove the right fender? hdsalinas Archived Corolla threads 6 12-10-2003 08:38 AM
