05 maintenance light staying on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2006, 12:43 AM   #1 (permalink)
View ekimwons's Photo Gallery
hello my name is mike snow and i am new to this forum and recently bought an 05 corolla. i have searched and found the threads on the maintenance required light. and mine started flashing upon starting about a week ago. signifying the need for an oil change. i understand the reset procedure, and have not reset the light yet, and tonight upon starting the light just now stays on for the continuation of the trip. i checked all fluid levels, or at least readily visible ones, oil looks fine, coolant is fine, never checked atf, i think the power steering fluid was within range. should i be worrying or not driving the car? or should i just get an oil change and reset the light? thanks for your help in advance guys, i have found this forum extremely helpful so far, until i can get my hands on a manual.
thanks
mike
afterthought: i have the le model could this car be equipped with a low tire pressure sensor? thanks
ekimwons is offline   Reply With Quote
Old 04-26-2006, 01:52 AM   #2 (permalink)
View arens's Photo Gallery
As far as I know that light will pop on at 5k miles, regardless of your actual oil change schedule. I know mine starts with the flashes on startup 100 or 200 miles early then stays on at 5k miles. Just take care of the maintenance yourself (oil change, air filter check/change, etc) and reset the light.
I am pretty sure there is a DIY write-up for deactivating the light, but I wouldn't recommend that until the warranty is out.
edit -- it won't let me put in the site with the DIY.
arens is offline   Reply With Quote
Old 04-26-2006, 05:21 AM   #3 (permalink)
Whine connoisseur
View adsaba1969's Photo Gallery
^^right. When the light flashes it's the "warning" of upcoming service needed. When it stays on it mean you should do the service now (based on when toyota feels the service should be done. The deactivate the light
adsaba1969 is offline   Reply With Quote
Old 04-26-2006, 08:04 AM   #4 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
As previously stated no need to be worried it will stay on once you pass 5K, just change the oil and reset the light
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 04-26-2006, 09:10 AM   #5 (permalink)
thanks so much guys
mike snow
How to shut off maintenance required light? RacerX001 1st Generation (2003-2008) 32 02-09-2012 04:31 PM
reset procedure Service Maintenance Reminder Light Suikelley 2nd Generation (2004-2010) 1 08-18-2007 11:24 AM
what do u guys think? Geius Maniacal 89-95 Toyota Pickup/Hilux 33 05-26-2006 02:45 PM
Maintenance Required Light j28vb 2nd Generation (2005+) 7 03-04-2006 10:13 PM
Bulb size? Ramenx 2nd Generation (2005+) 34 02-28-2006 12:11 AM
