Stupid Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2006, 07:13 PM   #1 (permalink)
View sdbct1's Photo Gallery
Stupid Question
Hi gang,
Sorry to be stupid, But Where is my PVC valve go/ I can't find the dam thing. I have a 97 1.6. Also The fuel filter? Is it a softball sized piece? Or a small clear plastic filter? Sorry for being Newbie here, But I'm tring these things on my own.
sdbct1 is offline   Reply With Quote
Old 04-27-2006, 07:18 PM   #2 (permalink)
Exhaust Time!
91_CorollaWagon's Avatar
View 91_CorollaWagon's Photo Gallery
Dont worry...ther are no stupid auestions....unfortunately...I cant help you!
John
[IMG]%3Ca%20href=%22http://forums.rpmplanets.com/vbpicgallery.php?do=hall&u=506%22%3E[/IMG]
91_CorollaWagon is offline   Reply With Quote
Old 04-30-2006, 10:21 PM   #3 (permalink)
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
Pvc cant help but the fuel filtter is a solid canister eg steel..if you are running efi..its about the hiet of a beer can and the diameter is two beer cans
hope this helps!......the lines attached to it wil be bolted on as its high pressure
WHen putting back on make sure the holes for fuel line up..it'll be a pin sized hole in the line
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
Old 04-30-2006, 10:38 PM   #4 (permalink)
The TN Member
View punter's Photo Gallery
PCV valve will be on the top of the head coming out of the cam cover, it will feed back in the inkake somewhere. (Don't know exactally where on your car).
If you post up a pic i'll point it out to you.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 05-01-2006, 09:07 PM   #5 (permalink)
cuzman's Avatar
On my 20v it goes into the rubber intake pipe befor the throttle bodies
Old 05-01-2006, 09:27 PM   #6 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
on my 4af it comes out of the top back side dead center of the valve cover
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 05-02-2006, 12:44 AM   #7 (permalink)
cuzman's Avatar
WHy do you need to find it anyway! they last for ever (pvc) and are only an emmision item at best!
Old 05-02-2006, 03:51 PM   #8 (permalink)
The TN Member
No they don't they can block up, crack case pressure is not desirable.
If its legal for you, you could run all the breather hoses into a catch tank, that way they don't feed oil into the intake.
Old 05-03-2006, 07:23 AM   #9 (permalink)
cuzman's Avatar
good point....just never seen a faulty one round here
just a a stupid question here about turbos 95 COROLLA General Discussion 5 12-01-2005 01:32 AM
stupid, dumb, retarded cardomain question? felkajamine Off Topic 7 01-13-2005 07:06 PM
Stupid Question, Diagnostic port or? SSC Archived Corolla threads 2 12-08-2004 10:36 PM
probably a stupid question AEugene86 General Discussion 19 06-20-2003 10:28 AM
