1996 Instrument Cluster Panel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2006, 09:49 PM   #1 (permalink)
View snigma's Photo Gallery
I want to remove that clear-plastic cover so that I can clean out the dust settled down below the gauges--so far, I can only see two screws in the top. That loosens the plastic shroud that covers the instrument cluster, but the bottom seems to be screwed in--and I can't find the screws for it.
The plastic shroud also rattles/vibrates when driving and its rather annoying (the screws are tight, but it doesnt seem to hold the shroud tightly )
Also, anyone ever done any LED mods for the instrument cluster to change it's lighted colors/brightness?
snigma is offline   Reply With Quote
Old 04-27-2006, 10:15 PM   #2 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
Take those two top screws out. The bottom pries out at the corners. It's in there pretty tight but be patient. Then 4 screws holding the cluster in and 3 wires to unhook at the back of it.
The plastic shroud probably isn't what's vibrating (unless you've put your hand on it and it stopped. It could be a number of things, maybe it's the plastic cover around the steering wheel shaft (where the turn signal and wiper controllers come out of). That thing rattles a bit for me.
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 04-28-2006, 05:49 AM   #3 (permalink)
Wild on the Flip Side
VooDoo's Avatar
View VooDoo's Photo Gallery
this might help...
http://www.grupotoyota.com.ph/board/...ic.php?t=12412
Grupo Toyota
VooDoo is offline   Reply With Quote
Old 04-29-2006, 02:28 AM   #4 (permalink)
Sweet--thanks, that really helps a lot
Ukrainian102, where did you find an instrument cluster with the tachometer? I'm trying to find one myself--do you have to do any mods (electrical) or does it just fit right in? It's really stupid that they didnt include them originally, but instead included an entire gauge just for fuel . vbmenu_register("postmenu_1229282", true);
Old 04-29-2006, 11:44 AM   #5 (permalink)
Ghostridin the whip
I found it at a junkyard near me. Go to car-part.com and find junkyards near you that have it. Call ahead and make sure what they have really has a tachometer before making the trip.
It plugs right in with the same three wires, no mods needed.
Instrument cluster was Smashed by thief... Quick question! newbie212 Camry & Solara Lounge 8 03-09-2006 07:44 PM
Instrument Panel Lights Not Workin goderaj 4Runner Lounge 0 01-26-2006 10:28 PM
Bright white gen3 camry instrument gauge cluster w/pics gen3guy 3rd & 4th Generation (1992–1996 & 1997–2001) 9 05-24-2005 11:37 PM
1992 Corolla DX Customer Instrument Cluster garryconn Archived Corolla threads 2 04-24-2004 10:07 AM
Camry (gen3) Instrument Cluster terrynham 3rd & 4th Generation (1992–1996 & 1997–2001) 8 04-03-2004 06:20 PM
