Brake/Battery Warning Lights On Together - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2006, 04:23 AM   #1 (permalink)
View CamryMan19's Photo Gallery
I'm trying to help out a good friend here. He's got a '91 Corolla DX wagon with around 175,000 miles on it. Runs okay but recently, his brake and battery warning lights have been on steady and occasionally they'll flicker but most of the time, they stay on. The e-brake is not engaged, brake fluid is fine, and the battery is brand new. What's the deal? Any help is greatly appreciated.
CamryMan19 is offline   Reply With Quote
Old 05-01-2006, 04:33 AM   #2 (permalink)
View karazy's Photo Gallery
As long as the charging system light is on, no other lights can be trusted. A low voltage situation can cause false signals. You should check the alternator and the battery, but check the connections first. They may not have been tightened properly on the new install. New batteries can be defective. I always recommend checking the alt, to make sure it wasn't the cause of the battery failure.
karazy is offline   Reply With Quote
Old 05-01-2006, 01:20 PM   #3 (permalink)
Drifta89's Avatar
View Drifta89's Photo Gallery
I agree. Check the alternator. My dad's 90 wagon had the same issue. His car ran fine with the warning lights displayed for a while and then it died on my brother. Turned out it was a bad alternator.
07 I4 LE (fully unloaded except for free mats and cargo net!)
Personal add ons: alarm w/remote start, XLE Grill, Lip Spoiler, OEM Sport Pedals
93 SlowRolla (Speed Isn't Everything...ah who am I kidding?)
Drifta89 is offline   Reply With Quote
Old 05-02-2006, 02:36 AM   #4 (permalink)
Thanks guys.
Old 05-02-2006, 07:56 AM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
We had this discussion a few times before.. a search would've netted you the same answer. Brake + battery light = Alternator or battery is dying.
Get the battery checked for charge hold, if it passes then your alternator is gone.
Another simple test, take the positive cable off the battery while the car runs, if the car shuts off then the alternator is dying, if the alternator is fine, it should be able to keep the car running.
Old 05-03-2006, 02:06 AM   #6 (permalink)
They tried unplugging the negative terminal while the engine idled and boom...dead as a doorknob. Alternator has been replaced and runs fine. Thanks again.
My bed Lights and Backup lights Pb 2nd Generation (2005+) 104 02-24-2011 05:35 AM
ABS, Brake and Tire pressure warning lights on!!!! DarkArcanine Archived Corolla threads 10 01-22-2006 09:15 PM
2004 Sienna, run flat tires and lights on warning light dah 2nd Generation (2004-2010) 0 10-22-2004 09:05 AM
warning light for rear lights rsmith021 Camry & Solara Lounge 2 08-10-2004 09:19 PM
My dash lights went out! xavior66 Camry & Solara Lounge 5 08-03-2004 01:38 AM
