The end-all thread for AE92 drum to disk rear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-02-2006, 08:21 AM   #1 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
Ok, I've searched and read everything, but there always were loose ends!
First: Do you need to change the master cylinder or proportion valve?
Second: Do you need to change lines?
Third: What parts are needed from the GTS to do the swap?
Fourth: What is the part number of the needed handbrake cable?
Fifth: Am I missing anything?
I have someone local that has a GTS they are parting out, and I would like to convert the SR5 to rear disc. I've heard that it doesn't matter either way, as the Corolla only uses the rear brakes 15% of the time, but I just don't want fugly drum brakes back there!
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Old 05-02-2006, 10:14 AM   #2 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
like I just typed in another post
"Why does everyone want disc breaks soooooooo bad.. a rear brake cylinder is cheaper to replace if it breaks. rear calipers tend to always sieze. Unless your takin the car to a track all the time it's not worth your time or money do to the swap"
they are more of a headache... one of the guys at the meet who used to have an ae92 was telling me they always sieze. I plan to keep the drums unless I get into some form of racing with the car. Which in that car I will find away to balance the breaks so the rears are used more
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 05-02-2006, 10:16 AM   #3 (permalink)
omg jdm
aaron7's Avatar
Disc brakes don't always seize. Whoever told you that obviously has other problems that they don't know about.
I want discs because they look better. That's all. I know there isn't really a difference in performance, as stated above, due to the rears only being used 15% when stopping compared to the fronts.
Old 05-02-2006, 10:37 AM   #4 (permalink)
View lifeisviewtiful's Photo Gallery
hey aaron7 when i spec'd out the rear brake conversion for my ae101 and found one on ebay, i needed the entire rear hub and a proportioning valve from the gts, and about 3 hours to spare. honestly the best way to do it would be to see if you can get the hub WITH the caliper and such attached to it. this will make the conversion as painless as possible. if you have the entire hub, then the only headache will be fixing back the hand brake. the proportioning valve is a necessity, or else the rear pads will wear out quicker than the front believe it or not.
hey freakinbox, i agree with aaron7 on the siezing issue, your friend probably did his rear conversion with a set of rear calipers that were fudged up and needed a rebuild.
lifeisviewtiful is offline   Reply With Quote
Old 05-02-2006, 10:48 AM   #5 (permalink)
omg jdm
aaron7's Avatar
I am getting everything already assembled from a GTS. I was told the proportioning valve doesn't have to be changed? See, I'm lost again haha!
I will be getting new calipers/pads/rotors too.
Old 05-02-2006, 11:33 AM   #6 (permalink)
Vroom?
freakinbox's Avatar
actually no! he was right they usually do sieze. COUNTLESS cars come into the shop for breaks and most of the ones that have rear disc have to replace the calipers. They don't have enough force applied to them and the slides start to fuck up. eventually the piston goes and then the caliper is done.
I know on domestics aaron you have to replace the proprotioning valve if you want the rear's to work proper after the conversion
and you might have to change the lines too since I don't think a caliper has the same fitting as a brake cylinder. and you can't put compression fittings on break lines (not here at least)
Old 05-02-2006, 06:28 PM   #7 (permalink)
omg jdm
aaron7's Avatar
Ok this was asked by the person with the parts car that I'm buying the parts from:
today i was taken off the calipers with the E-Brake bracket & mounting bracket but i notice there is the bigger bracket for the lower, upper ,and sway bars that the mounting bracket with the caliper bolts onto, you will also need that, and my question is will you also need the axels, i would not know if the SR5 are the same
Old 05-03-2006, 07:40 AM   #8 (permalink)
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
I was told by my parts importer the proportioning valve has to match eg drum for drum disk for disk...ihave so far changed every thing brake related to gt.....except the rear drums and proportioning valve...it all works sweet on the road even under extream braking around the mountain areas...
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
Old 05-03-2006, 08:15 AM   #9 (permalink)
omg jdm
aaron7's Avatar
Wait... so what did you change if you still have drums?
Old 05-06-2006, 04:58 AM   #10 (permalink)
cuzman's Avatar
booster,master,calipers,disks,backing plates,hubs,bearings..and bigger wheels as you need at least 14 inch to fit over the caliper...no line change as it bolted up..left the pro valve back stock for now!
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 05:51 AM
rear end, supercharger... ojom Previa Forum 4 07-09-2006 02:23 PM
identifying gear ratio for 2wd rear end subliminaltrips 89-95 Toyota Pickup/Hilux 5 11-22-2005 12:35 PM
Rear end squeeking under turns alex86 Camry & Solara Lounge 0 02-27-2005 12:26 AM
