I have a 91 Corolla and was thinking about getting a K&N Intake kit (
http://shop.knfilters.com/KNShop/Pr...spx?pid=57-0115). What are your suggestions on it and will I have to worry about getting a water bypass valve so water doesn't leak in? I have a stock Corolla DX so I believe to engine is a 4afe.
My brake fluid is leaking. I found out where the fluid is leaking to and I was wondering if that was something I can fix myself or should I have a mechanic fix it. Also, is there any brake parts that should be replaced because of the leakage?
Grr, forgot. Also, on my drivers side door, the key lock is broken, so to get into my car, I have to open the lock from the passenger side. Does a local repair shop like Pepboys fix this? I have manual everything (locks, windows, mirrors, etc.) =/ Thanks.
Also, where do sway bars go? Under the car?
