Idle Problems! Help Please! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2003, 08:55 PM   #1 (permalink)
View TigerSilhouette's Photo Gallery
Hi
I was wondering if anybody could solve my problem.....I have a 93 Corolla LE and whenever i turn on the airconditioning when the car is cold, the revs drop and the car almost stalls....but it doesn't. When the car is warm, it does not do this, it only does it when its cold (aka when i first start the car or something) I took it to a shop, but they weren't sure what was happening...I posted about this before, but nobody really responded. I don't want to take it to the dealer yet so i wanted to ask you guys... If anybody has any thoughts, please post.
Thanks
TigerSilhouette is offline   Reply With Quote
Old 02-17-2003, 09:46 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Hmm, on carb'd rollas, theres an idle compensator that lifts the revs when the compressor starts spinning, I would imagien the EFI having a similar deal, so might wanna check that out.
Old 02-17-2003, 10:01 PM   #3 (permalink)
FlashMn, in all my posts you are like the only person who actually replies...I thank you for that Idle compensator hmm? There is something i saw in the back of the engine that might be what your talking about...i hope you guys can see the picture
Old 02-18-2003, 02:10 AM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Hmm, nope that doesnt look like it, because on the carbie the compensator is right there with the carb, and connects to the throttle butterfly, I'll consult my manual and get back later today.
EDIT: btw, what are those two blue boxes on the left side?
Old 02-18-2003, 02:33 AM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Hmm, well accoding to my book, the aircondition control goes through the ECU and so then the AC idle up should be controlled via the ECU aswell. Hmm, one thing you could check is the VSV- or idle up valve on your intake manifold. the VSV connects to the vacuume tank and has an actuator on it, its possible (now I'm not sure if it controlls the idle of the AC) that the actuator diaphragm has gone bad and therefor it wont up the idle when the AC turns on. Another thing you chould check for is that your idlespeed is ok without timing advance, it should be 800rpm at 10btdc.
If you want, as a remedy for now you could either lift the idlespeed a little, like 100rpm or just wait for the car to get warm before using the AC... hope this is of any help.
Old 02-18-2003, 03:06 PM   #6 (permalink)
Thanks for the replies Flashmn, that information really helps me out....i'm going to go get the a/c actuator checked out tomorrow....oh and the blue boxes are ignition control boxes.
