Alltrak 4wd owners info! - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2006, 06:41 PM   #16 (permalink)
big_fella6699's Avatar
View big_fella6699's Photo Gallery
i live in tassie n i own an ae95 4wd rolla, it has a 4afe and the previous owner put some 4-1 extractors. it handles ok 4 a wagon, it has fron and rear swaybars. but yea, does any1 know how 2 get a lil more power from the engine? (its gutless uphill) or would i be beter off putting a 4age in it? cheers
big_fella6699 is offline   Reply With Quote
Old 11-14-2006, 10:10 PM   #17 (permalink)
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
Australia
Yer try pissing off the 4 to 1 and going longer secondairys..eg 4 2 1 .....2inch system good muff on the back,cold air with good filter.
i went for the swap and it has cost a far amount of money but the gain is more than worth it!..it is now a good car with power and grip!
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
Old 11-14-2006, 10:17 PM   #18 (permalink)
oh ok awesome, yea i've heard that before, apparently 4-1 extractors only give u a lil more high end poke while 4-2-1 gives u better midrange... i have been considering this 4 a while. cheers 4 ur advice. also, would there be much of a performance gain in swapping the 4afe with 320000 ks on it 4 a 4age?
Old 11-14-2006, 10:30 PM   #19 (permalink)
cuzman's Avatar
320,000 what the it must be getting tired? the difference is like a hammer and a mallet!
Old 11-14-2006, 10:31 PM   #20 (permalink)
cuzman's Avatar
The all trax /or 4wd as we know it needs a bit of low down grunt to get going due the the drive train mass
Old 11-14-2006, 10:35 PM   #21 (permalink)
cuzman's Avatar
Messenger.
justinlinton@hotmail.com jump on!
Old 11-15-2006, 03:09 AM   #22 (permalink)
AWD Grocery Getter
Kebin's Avatar
View Kebin's Photo Gallery
Australia
Its about time i found a thread like this!
Here in Australia, I have an 1989 AE95 Corolla SR5 4wd i bought off ebay that im in the process of completly modifying.
Originally Posted by cuzman
c. Any 4AGE will fit (except the 4AGZE) the charger sits were the centre diff goes!
- Incorecct
I have just fitted an ae101 4agze engine to my wagon
Notable modifications are:
> Cutting out ribs in the block and shaving part of transfer case to make it fit. From my research i have found that most 4a motors need this same modification to fit in an ae95. Some 20v motors fit?! i havent seen one with the same block rib pattern as a 4afe.
> Yes the original vacuum operated diff lock will not work due to supercharger being in the way. You can either turbo your motor to retain this setup or do what i did and remove it completely. you can run no diff lock or operate it manually by pushing the shaft in/out with your hand (not easy). I am currently working on a electric diff lock using electric solenoids.. i've installed them just havent wired them up to test.
There are plenty of other mods but nothing too big... i will do a complete diy write up on the aussie forums and link it here.. i just need to do more work
Kebin is offline   Reply With Quote
Old 11-16-2006, 03:46 AM   #23 (permalink)
cuzman's Avatar
Yer good call just found that out .but not willing to post it until i know for sure!
So now all 4age series fit..the ribs are the same you mean the bolt location extensions for excesiories? my 20v was easy except for a small amount of grinding on the bolt location for the centre diff to match the 4afe block.
also try www.twincam.org/forums its more aussie with a better understanding of ae95's
Old 11-17-2006, 04:58 PM   #24 (permalink)
AWD Grocery Getter
Kebin's Avatar
Yeh twin cam is a useful site with alot of info..
except there isnt alot of ae95 owners who have modified their wagons... so not much info. there are like a handful i know of. Only like 3 people, who have done the 4agze engine conversion
Old 05-07-2007, 05:15 AM   #25 (permalink)
AWD Grocery Getter
Kebin's Avatar
update update!!?!?!?!?
Anyone else have one, modified one???
Old 05-07-2007, 05:47 AM   #26 (permalink)
pod filter and extractors but thats about it... my parents bought it with extractors and a 2 inch catback but they took the catback off
1988 ae95 corolla - extractors, pod filter - SOLD.
1986 mazda 929 turbo - 2.5" catback, boost cont, bov - DRIVING (for sale).
19** ke70 corolla, chopped springs all round, welded diff, more 2 come... - DRIVING.
Old 01-01-2012, 09:23 AM   #27 (permalink)
runamoktoo's Avatar
View runamoktoo's Photo Gallery
Ok. heres some pictures of my rolla sedan. and one of my two camry all-tracs and my rolla wagon all-trac. On the sedan I have used truck bed liner on the interior metal, trunk and entire undercarriage to keep it rust free and as a sound deadener.
runamoktoo is offline   Reply With Quote
What's your MPG? 4WD vs. 2WD voodoobike 2nd Generation (2005+) 48 09-13-2007 05:58 PM
A Wealth of Info (Road Test/Stats)3rd Gen V6 Camrys (long) Structureboy Camry & Solara Lounge 4 07-20-2006 07:09 PM
HELP - 4WD Engaged??? davet100 T-100 1 12-06-2005 09:27 AM
Any 89-92 Cressida owners ? Need info 93 Camry LE V6 Cressida Forum 7 05-09-2005 10:34 PM
03 Corolla S & LE Owners - Firestone Recall Info Phi Archived Corolla threads 2 09-30-2002 11:24 AM
