squealing not going away - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-07-2006, 07:00 PM   #1 (permalink)
View GuJu MaN 89's Photo Gallery
ok ive changed all my belts like 5 times in the past month and the squeling is not going away. it stops if i turn the air fan off, so it cant be related to belts if teh belts are still spinning when teh fain is turned off. what can be causing it?
its a 97 corolla
GuJu MaN 89 is offline   Reply With Quote
Old 05-07-2006, 08:51 PM   #2 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
the blower motor would if it stops when you turn the climate control off...
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 05-07-2006, 09:01 PM   #3 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
Yep. Sounds to me like either the fan motor or the A/C Compressor...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 05-12-2006, 11:26 AM   #4 (permalink)
View gekishibu86's Photo Gallery
I would first check if I have the proper tension on the belt before I change anything. Then, I would replace the belt if tightening doesn't help. I had the same problem with my 92 Prizm GSi and what cure my problem is replacing the belt with a different groove design. I have the problematic Goodyear and replaced it with the sock design.
gekishibu86 is offline   Reply With Quote
slight squealing during idle then stops 89SV21 Camry & Solara Lounge 9 03-06-2006 03:22 PM
Squealing brakes dcarter124 Camry & Solara Lounge 14 11-10-2005 12:50 PM
need help... consistent squealing while driving? HPR Archived Corolla threads 1 09-22-2004 08:56 PM
Why you should check that squealing belt (pics) brink Off Topic 14 12-18-2003 09:51 PM
