That should work, as the door trigger is ground. I've actually done this setup in a different way with the passenger side as a map light as well. So you have a map light on the passenger side, a master that turns both ON and a switch that will turn both on upon the door opening.
This is as simple as putting a relay inline with the drivers side LED, attaching the positive side of the magnet to a constant power source and the negative to the door switch...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
