When to change timing belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2006, 08:46 PM   #1 (permalink)
View samp55's Photo Gallery
Hi,
I have a 2000 Corolla. Does anyone know when a timing belt should be inspected/replaced on a Corolla? I checked the maintenance manual and it only specifies the replacement interval for other Toyota models such as Camry. Thanks in advance.
samp55 is offline   Reply With Quote
Old 05-10-2006, 09:40 PM   #2 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
The 1zz-fe in the 2000 Corollas from memory is a chain, and therefore doesnt need to be replaced...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 05-11-2006, 03:48 AM   #3 (permalink)
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
Take off the cam belt cover and have a look.......
if its rubber change between 70,000km's -100,000km's
This is a good safe schedual..
If ya drive hard go the first option...
If ya got a chain which i doup for a 2000 mdl car only change if it gets noisey
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
Old 05-11-2006, 11:42 AM   #4 (permalink)
View 92MX83's Photo Gallery
I had a 2000 Corolla. It's got a chain. The tensioner will wear out, so best to check it at the normal timing belt change intervals, about every 60-90K miles. Replace the tensioner if necessary
"Crush enemies, see them driven before you, and hear the lamentation of the women!" - Conan the Barbarian, on what is good in life
92MX83 is offline   Reply With Quote
Change in timing tension spring? awmccready Camry & Solara Lounge 5 11-26-2004 10:15 PM
Timing Belt Change Interval for '97 Tercel 1.5L chuckhammer Tercel, Paseo, Starlet, and Sera Forum 8 04-20-2004 08:37 AM
timing belt change and ac not working anathemata Camry & Solara Lounge 12 03-25-2004 05:39 PM
shift point different after Timing belt change ']['R][) camry Camry & Solara Lounge 2 12-07-2001 03:04 PM
