Turbo AE92 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-12-2006, 08:47 AM   #1 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Turbo AE92
Heres a pic of the engine at its current state.
Old 05-12-2006, 11:21 AM   #2 (permalink)
View toyloco's Photo Gallery
Tell us more about this?
What are you doing to control the fuel system to add additional Fuel under boost?
Those look like Supra Injectors?
Did you lower your compression??
..Etc etc etc....
Very cool also by the way..
toyloco is offline   Reply With Quote
Old 05-12-2006, 12:26 PM   #3 (permalink)
Gameroom cash: $134355
hmm.... was about to say those injectors are a bit small until i realized it's a dual rail setup
Old 05-12-2006, 01:06 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Yup, smaller injectors give better control over the lower rpm band fuel delivery when you dont need much.
Some specs:
Fuel delivery is done with 2x 3S-FE injector banks, using 200cc/min and 210cc/min injectors.
Fuel delivery control is achieved with MS ECU.
Ignition timing control is done with VPV-Motorracing ignition controller
Exh. manifold is done by me as is the intercooler piping, I'm using a mercedes C200 Kompressor intercooler for the setup and an MSD high pressure fuelpump for fuel delivery.
And no, I havent made my modified head yet, so the compression is still 9.5:1
Old 05-12-2006, 03:15 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
I've seen internally un-modified Turbo 4AFEs so I know it's not neccessary, but the question would be.. would it make a diff if you did?
Old 05-12-2006, 03:26 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Yeah, I could run higher boost and get alot more power from that, on the down side, off boost response would suffer a great deal.
Old 05-12-2006, 04:42 PM   #7 (permalink)
depending on the amount of boost... 410cc/min (combined... were both to be at 100% duty cycle) may not be enough.....
my setup i'm planning on finding around 500's for (max) 15psi....
if you want to turbo your fwd 4age epyon22 Archived Corolla threads 6 05-12-2006 09:09 AM
Twin charged ECU? Blazin674 Archived Corolla threads 30 04-11-2006 08:25 PM
History of the Turbo... puzzle man General Discussion 4 01-24-2006 03:41 PM
Stock MR2 turbo comparisons Piddy MR2 Forum 20 02-07-2005 05:22 PM
