Can't get something right (4AFE) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-12-2006, 12:37 PM   #1 (permalink)
View No_Bs's Photo Gallery
Alright, here's the low down. At 210,000 miles my corolla blew the head gasket, nice white smoke (it didn't overheat). So I changed the head gasket, and now I cannot get the car to run. I double checked the timing belt and the camshaft alighnment. The distributor is pointing at number 1 at TDC, and everything looks to be right. With the distributor turned completely to the back of the car it'll sputter for a second or so but that's it. It's really frustrating.
No_Bs is offline   Reply With Quote
Old 05-12-2006, 01:00 PM   #2 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
did you clean out all the shit on the inside, all the white stuff. and torque the bolts down proper after? and have the timing right?
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 05-12-2006, 01:26 PM   #3 (permalink)
I torqued the bolts to the correct ft-lbs in the right order, and cleaned everything that needed to be. The timing belt and cams are correct. I just tried new plugs and it made no diffrence. The car ran good before even with the blown gasket. It's a 1990 also.
Old 05-12-2006, 02:19 PM   #4 (permalink)
Gameroom cash: $147537
You installed both cam shafts correctly? Sounds like you cam tming is off. Try to see if you got compression. If not, your cams are way off. I believe you align the crank and cam pulleys correctly? Check all electrical connections. I think there is a gound on the intake manifold. Its ground for the ECU. I didn't tight the bolt once and had lots of fun finding that one.
Old 05-12-2006, 02:22 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
the timing might be off a little, double check everything
how did you torque them... you should go over the pattern a couple times
Old 05-12-2006, 02:43 PM   #6 (permalink)
The cams are in right, the marks line up perfectly with eachother. The timing belt is also right and it's not the first time I've done that. I torqued the head bolts in the pattern in steps of 10ft-lbs. Checked that ground and it's tight. Just another thing, one of the exhaust maniflod studs broke when I was taking it off, so it's not hooked up right now. I don't believe that the oxygen sensor would cause this problem though. When I just went out I got it to rev once before dying with the distributor rotated fully clockwise, so it getting fuel and spark. I also took the valve cover off and checked the timing belt alignment, all valves are closed on #1, the distributor is pointing at #1, and #1 is at TDC.
Old 05-14-2006, 01:11 PM   #7 (permalink)
Ok, I went to a U-Pull it today and checked out a motor exactly like mine. Took the valve cover off and the distributor cap and aligned the timing sprocket to 12 o'clock. Everything looked the exact same as mine. So if it's not internal in the engine, what else could cause this behavior?
Old 05-14-2006, 03:05 PM   #8 (permalink)
Vroom?
freakinbox's Avatar
check for spark
Old 05-14-2006, 08:11 PM   #9 (permalink)
I know it has some, I guess I'll check every plug though.
Old 05-17-2006, 04:08 PM   #10 (permalink)
Every plug is getting spark. I tried to see if it was throwing any codes but the light just blinked, no pauses.
Old 05-17-2006, 07:12 PM   #11 (permalink)
Alright! I got it started. All I did was charge the battery a little, clock the distributor fully clockwise, replace a missing crush washer I found in the cold start injector system, and give it a little gas. I don't know what actually worked, but I'm happy now. Runs good with no smoke at all. I timed it but still need to fix a few odds and ends before getting it back on the road.
Old 05-17-2006, 07:14 PM   #12 (permalink)
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
has the exact same prob on a corona after a new timing belt and dizzy....i was sure it was all good and checked every thing including the fuel..it had spark,the timing belt was right..had good compression ,all wires were hooked up..etc.......the bloody dizzy was off one notch..it acually looked right but i figured stuff it and moved it anu way! started first kick lol....
Also make sure you did'nt tap the plug gap down by mistake while doing the head!
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
4afe --> 4agze alternator pinouts? HELP plz mhiscott Archived Corolla threads 0 05-07-2006 05:39 PM
4AFE transplant Dave99 Archived Corolla threads 8 05-02-2006 01:19 AM
Will a 1990 4afe head fit my 1997 4afe? nolragan Archived Corolla threads 7 11-02-2005 07:53 PM
90 ST 4AFE replacement jap motor questions RyanGriffin Celica Forum 3 10-03-2005 07:37 PM
4afe & 4age Head? bluedemon Archived Corolla threads 24 06-30-2004 05:20 AM
